Old 04-29-2004, 11:53 PM   #1
Tom & Janet Salhus's Avatar
Numeric Entry Door Lock Combination/reprogram
Hello, We are new, somewhat, to the form. We bought our 345 LE last fall(2003) and it has a numeric entry door combination lock on it that the P/O somehow forgot the combination to. So, does any body know how to change, or reprogram this lock. I dont know that we would use it but in case it would lock somehow I would like to get in to our home. I could disable it totaly but it is kind of neat. Any help would be great. Best to all and a wonderfull summer. Tom
Tom & Janet Salhus is offline   Reply With Quote
Old 04-30-2004, 09:43 AM   #2
donnall's Avatar
Yon can email Airstream and give them you VIN or serial #, they will send you the original code and instructions on how to enter your own personal code.
At least they did for me.
I just use the factory set code and it works fine.
HTH
Don
Don Nall
93 Land Yacht (The Minnow)
donnall is offline   Reply With Quote
Old 04-30-2004, 11:14 AM   #3
Entry door code
Thanks Don, I just called A/S and they do not keep the codes any longer. I am going to look around the door hinge and cabinet door as had been suggested on anothe post and see if I can find somthing there. Thanks, Tom
Old 04-30-2004, 01:50 PM   #4
Elgin , Texas
Images: 164
look on the control module itself
In another thread about keyless entry it was mentioned that the main control module for the keyless entry unit had the permanent code affixed as a label to the module. Also, it seems to have been made by Ford.
Here is the thread.
Here is another that mentions the label on the module and it's whereabouts (on a TT).
bake315 is offline   Reply With Quote
Old 04-30-2004, 02:59 PM   #5
Hello All, Dave, Thanks for the info. on the for "motocraft" box. I found mine under the sink on the curb side, a 5"x3" box (plastic) on the wall with a # on factory ID tape with a 5 didget # and became a "contortionist" with a couple realy good charle horses but I punched the # in and "WALLA" it worked. Well another stunning mistery solved. I bet there will be more guys and gals out there in the A/S tonight crawling around on the floor with a mirror and flash light looking for the"BOX" Thanks very much for the comeback and the info. that even A/S factory could not supply. Tom
Old 04-30-2004, 03:24 PM   #6
Elgin , Texas
Images: 164
Glad you were able to use that info.
Aren't forums great?
Old 06-09-2004, 11:06 PM   #7
Hi all, speaking of the digital entry (using instead of key), how do I get it fixed? It quit working and I can't find any info in the owner's notebook about it. I have a 92 motorhome.
Thanks in advance for your help--you folks have always come through.
Alice
Alice is offline   Reply With Quote
Where to get keyless entry code? 0557 Our Community 23 10-08-2017 10:42 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Keyless entry grogan Doors & Locks 2 04-20-2004 12:16 PM
Entry Door Questions sladew Doors & Locks 22 12-13-2003 07:43 AM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 09:16 PM
