Old 09-26-2015, 02:21 AM   #1
Bossier City , Louisiana
Newbie -- AS 310 Battery Compartment
Hi Just purchased my Airstream 310 MH and the Battery Compartment was crunched -- does anyone know where to get one? also where to get parts in general for this motorhome. . .
Thank You Again,
Gman1957
Gman1957 is offline   Reply With Quote
Old 09-26-2015, 04:52 AM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Airstream parts vendors:
Classic Motorhome 1979-1996
Airstream Road Sign 26369W-38 [26369W-38] - $10.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Inland RV Center Inc.
very informative thread started by our friend and Leidensgenosse (fellow sufferer) Keyair :
http://www.airforums.com/forums/f311...ead-95034.html
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 09-26-2015, 07:10 AM   #3
Thank You Again,
Gman1957
Can you post some pictures showing the damage to the battery drawer?
Old 09-26-2015, 08:03 AM   #4
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
If yours is like or 310, you will probably want to find a sheet metal FAB shop in your area and have one made up. It is a heavy gauge 10 or 1/8" metal. It would take a break to make the bend, drill press for the mounting holes and a little welding for the outer supports. I can take more photos if you would like. I had to drop mine a little so the golf cart batteries would clear.
ID:	248982Click image for larger version
ID:	248983Click image for larger version
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 09-26-2015, 01:03 PM   #5
310 Battery Box
Thank You Peter and Brad
1. I will post some pics of the banged up box when I get home from work.
It was bad enough that the slider was bent and not holding the box up. We didn't think it would hold the battery on the way home from Lafayette, LA to Shreveport so we removed it and wired the battery in the small round cargo box above where it originally went. -- Worked fine for now but needs fixxin.
Thank You cmadmaxman, however mine doesn't look anything like that but the idea of finding a sheetmetal shop is a solid one and I will do that.
Thank You ALL!!
Old 09-29-2015, 08:16 AM   #6
cmadmaxman's Avatar
Images: 37
Battery tray in our 1982 310
Here is some shots of the tray in our 310. I had to notch out for the new steps, and about ready to put Optima Batteries in. Tired of fighting the acid!
AIR Member 12654
1982 310 MoHo
Old 09-29-2015, 08:40 AM   #7
mayco's Avatar
champaign , Illinois
In '82 the battery box was "fixed" just inside the door, in the '83s its a slide out battery tray. I believe Gman has the slider.
mayco is offline   Reply With Quote
Old 09-29-2015, 11:34 PM   #8
cmadmaxman's Avatar
Images: 37
Yes I know. He wanted to see what I had, and did not see where I could put the photos on the PM service, so I just added them to the tread.
AIR Member 12654
1982 310 MoHo
Old 09-30-2015, 06:08 AM   #9
mayco's Avatar
Gorgeous work on your compartment there cmadmaxman.
Mike
Old 09-30-2015, 10:41 AM   #10
cmadmaxman's Avatar
Images: 37
Thanks Mike, it looked better until the battery acid make its mark. Even have the anti-acid pads under the 2 batteries. I'm afraid to see whats under em!
AIR Member 12654
1982 310 MoHo
Old 09-30-2015, 11:26 AM   #11
mayco's Avatar
That looks like real wood flooring.....is it?
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
Battery Box Compartment AccessMaster Airstream Motorhome Forums 11 05-03-2003 09:00 PM
Doors for Battery and Stowage Compartment Joe Davis Exterior Storage Compartments & Access Doors 4 03-07-2003 06:27 AM
battery compartment mods nwclassic Our Community 13 02-18-2003 06:46 AM
