Old 09-14-2006, 08:22 PM   #1
1975 26' Argosy 26
HARTWELL , Georgia
need advice - leaking Argosy moho
I recently purchased a 1974 26' argosy motor home. After I tore up the
carpet I noticed there is a leak where the floor meets the side wall under
the two windows by the dinette table. Do you think this leak comes
from the window itself or outside above the window where the window
frame meets the skin of the rv? What do i use to seal this area?
Also, I noticed the three vents on the kitchen/bath side have no caps on
them and are stuffed with screening but no cover. Is this ok since it runs
into the drain to the gray/black tanks?
What do you recommend I use to seal around the ac on the roof and tv
antenna, etc.
Still can't figure why my interior lights, fans, etc. only works when the
ignition is turned on? Thanks
DONP is offline   Reply With Quote
Old 09-14-2006, 10:21 PM   #2
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
Hello Don, I have a 77 argosy moho and had a leak in the same place. It was the hot water tank .look under the rear seat in the seat box. the water leak was against the wall making it look like a window leak..
bobchevy89 is offline   Reply With Quote
Old 09-15-2006, 05:42 AM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Sounds like a nice project you have there.
Have you looked at Vintage Trailer supply . com?
Vulkem works about the best.
Is the leak from the antenna coming from the shaft thru the roof, may be an O-Ring that needs to be replaced. Not a fun task. May need to seal around the base of the antenna. Check this link out for a leak similar to yours
http://www.balrgn.com/Airstream/Leak/leak.htm
Can you post pics of your vents, sounds like you should look into replacing them.
Interior lights? Do you have 2 batteries? I have a switch that transfers the power from the RV battery to the ignition, not a good thing if you want to maintain a full charge. Do you have power to the DC lights when you are plugged into shore power?
Check out my restoration on my '77 20' Coach
http://www.balrgn.com/Argosy/20/Argosy_20.htm
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
2009 19' Bambi W/H leaking - need advice BandL Water Heaters, Filters & Pumps 2 04-27-2014 01:36 PM
Advice on replacing A/C condenser on '79 24 Excella MoHo djurgensen Mechanics Corner - Engines, Transmission & More... 8 10-05-2012 02:32 PM
Quick advice on leaking regulator johnobuttons LP Gas, Piping, Tanks & Regulators 6 10-03-2009 04:50 PM
Need Advice - MOHO or TT hapitauk Member Introductions 10 11-15-2008 10:11 AM
Water Heater T&P 99 Bambi Leaking, need advice JimBrownUT Water Heaters, Filters & Pumps 3 01-14-2004 03:46 AM
