Old 08-14-2009, 12:31 PM   #1
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Motorhome Water Leak:
On a trip last week I noticed water dripping from the rear of the right rear wheel well. The flow increased until we only turned on water pressure when we needed to use water of cleaning or cooking. Now we are home and I need to find and fix the source of the leak.
Looking at the diagram it appears it may be where the main water line to the kitchen sink is connected to the shower. My only problem is how to get to the pipe to repair it.
Must I pull out the shower? I really hope not as it looks like quite a job.
Fortunately no part of the floor is wet either in the kitchen or clothes closet.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 08-14-2009, 12:47 PM   #2
The Hawk's Lair
cooperhawk's Avatar
For some reason this did not show up in new posts and only in the Portal. Lets see if it does now.
AKA THE GUNNER
VFW, LEGION, NRA
Old 08-14-2009, 04:12 PM   #3
1986 34.5' Airstream 345
Tyler , Texas
shower leak
Hi! Before I decided to pull out the shower stall cut an access hole in the closet and check the shower valve. There should be a T or Y fitting at that point.and if you pinpoint the leak you can pull the new line thru using the old pipe as a fish line. Although I have not had the problem in the mh I have found many a house valves leak. Pete
pjude is offline   Reply With Quote
Old 08-15-2009, 08:43 AM   #4
The Hawk's Lair
cooperhawk's Avatar
Thanks. That's a good idea and I will definitely try that.
AKA THE GUNNER
VFW, LEGION, NRA
Old 08-15-2009, 11:22 AM   #5
Robfike's Avatar
Speedway , Indiana
Cooperhawk,
There should be a false wall in the closet. It starts about half way down the wall between the closet and shower. It will come off with a few screws. Inside this area is the back-side of the shower faucet, and associated plumbing. If you pull the drawers out from under the microwave, you will have access to the plumbing forward of the shower.
Let us know what you find.
Rob
Robfike is offline   Reply With Quote
Old 08-15-2009, 12:09 PM   #6
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Also remove the drawer below stove top, can see lots from there, and if you remove microwave, and can squeeze back in there, lots to see, maybe see leak location, but would be tough to repair.
but leak stops when you turn water on in other locations?
maybe supply from pump?
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Motorhome Water Leak: cooperhawk General Motorhome Topics 3 08-18-2009 09:08 AM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
1974 safari water leak when hooked to town water Jasper_pilot 1974 - 1979 Safari 8 06-09-2007 02:18 PM
water leak- hot water tank vent glacierrunne Water Heaters, Filters & Pumps 2 05-29-2006 07:14 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
