Old 10-05-2012, 03:59 PM   #1
Happy Trails
bhunt's Avatar
2005 16' International CCD
Delaware , Ohio
Motorhome Travel in Winter
We just bought a 2004 Airstream Land Yacht motorhome (31 ft.) and plan to take it from Ohio to Florida this winter. I'm concerned what to do during the couple of days in freezing weather with three pets on board and a wife, too. Do we travel with it winterized until we reach warm weather or is there some way to prevent it from freezing up for a few days? Do we just run the generator the whole way, or will the chassis heater be enough? Someone out there must have experience with this. Please help.
bhunt is offline   Reply With Quote
Old 10-05-2012, 05:25 PM   #2
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
We have a 2005 LY motorhome that we have taken south the past 2 winters. (MI to Gulf Shores AL) We leave in Jan.& return in March. This is what we do....We keep it winterized. The morning we leave, the furnace gets turned on to warm everything up. We do not run the generator or the furnace while driving. The chassis heater keeps everything toasty. I think the pre-heating before we leave makes a difference. Once the moho is warm we pack the things that might freeze...we take several gallon containers of water for drinking, washing up & flushing. A long time RVer told us we could travel with water in the fresh water tank...just leave expansion space. We prefer not to tempt our luck. But, we dump water down the drains once on the road. We've not had any problems with this system.
When we stop for the night we haven't had to use the generator for heat until the next morning. The moho holds the heat pretty good. We use plenty of cozy/down blankets though. We also travel with our dog. She just snuggles in...not a problem for her.
A couple of other things we learned along the way...A small electric heater is all that is necessary most of the time. Once south we used one most mornings to take the chill out. And, the water in those gallon jugs will be COLD in the morning. Not frozen, but you'll wake up fast...so bring something to heat some clean-up water in.
One last thought, check the weather & if you can be flexible on departure dates, give yourself a 2 day window of decent weather. We did this the 2nd year & there was no snow, ice or salt on the roads. That makes the drive south so much more enjoyable. I hope this is helpful.
Schools Out is offline   Reply With Quote
Old 10-07-2012, 10:23 AM   #3
Happy Trails
bhunt's Avatar
Delaware , Ohio
Thanks so much for your answer. Nothing like experience. I assume the various northern RV parks are closed in January. Do you stay in Wal Marts, truck stops, etc. on the way south? But there must be some RV parks open at some point in the south. Do you un-winterize in one of those, or wait until you get to Gulf Shores to handle that?
Old 10-07-2012, 03:48 PM   #4
Rockford , Michigan
Images: 12
You're welcome. I'm happy to offer what we've learned in our 2 year experience:-)
The first open parks we see are in southern TN & northern AL. That's too far for 1 day's driving/traveling. I'm not a fan of Walmart "camping" or truck stops...so here's our secret. (again suggested by a long time RVer.) We stay at a Cracker Barrel or a casino RV lot. Both provide RV parking & usually are well advertised along the interstate. Cracker Barrel is my preference. We usually have dinner & breakfast there & we always let the management know we're in their lot. Never had any issues with doing this. We have been told that FL doesn't allow overnight stays in parking lots. But, by the time you get to FL, there should be open campgrounds.
As far as un-winterizing goes...that happens when we get to the park & hook-up all the systems. If you stay at a full hook up park, the flushing of the system just happens with use. We continue to use bottled water for drinking...just to make sure all the lines are thoroughly rinsed out. If we're lucky, the temps will remain above freezing while south. There were a few times when the RV park asked people to open a faucet just a trickle, to prevent their outside pipes from freezing. If you will be staying in the panhandle, that's a possibility. Where are you staying in FL?
Again, hope you find this helpful.
Old 10-08-2012, 06:48 PM   #5
Happy Trails
bhunt's Avatar
Delaware , Ohio
Thanks again for the useful information. In answer to your question, we stay in Fort Myers Beach.
Old 12-08-2012, 07:38 AM   #6
RAG
RAG's Avatar
2004 30' Land Yacht Gas 30
Canadensis , Pennsylvania
Is there a reason you don't run the furnace during the drive or at night when stopped; it is 12 volt, right? I have an '04 LY and use the furnace whenever needed and always without the generator.
Also, as the tanks are heated, we use all the facilities when winter traveling; driving or parked. Am I missing something? I would hate to be making a mistake.
RAG is offline   Reply With Quote
Old 12-08-2012, 08:26 AM   #7
Lily&Me's Avatar
Normal , Illinois
For us, and probably you as well, there is a fair amount of heat generated inside the motor home just from running it for the better part of the day. We just don't need the furnace on during the day. If the grands happen to be with us, we have blankies.
If it isn't that cold out, the furnace isn't needed at night for warmth. If it is that cold, we run the furnace or get a site for the night with electricity.
If it is warm enough inside your RV for you, it is warm enough to keep pipes, tanks, etc. from freezing, is what we have always been told.
Maggie
Old 12-09-2012, 07:38 AM   #8
Rockford , Michigan
Images: 12
Rag, Pretty much what Maggie said....we have never needed to supplement the chassis heat while driving. When we stop at night we run the furnace as needed...but, we usually don't need heat until the morning. Then we turn the furnace on...is it 12 volt? We have always started the generator. Next time we'll try it both ways.
Old 12-09-2012, 10:09 AM   #9
RAG
RAG's Avatar
Yes, it is definitely 12 volt.
Thanks for responding....
Old 07-12-2013, 11:34 AM   #10
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I am not certain about your Land Yacht but we used to winter camp in our classic all of the time. One year my son and I spent a week at Canton and Cleveland, OH in January sub-zero weather. Then there was the memorable trip when we ended up at Jackson Center on New Years Eve. As long as we kept the interior warm nothing froze. Another Ohio adventure was a campground along Lake Erie. We had so much snow overnight we could not open the door. There are many northern campgrounds which stay open all winter and people who use them.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 07-12-2013, 12:56 PM   #11
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
In my (admittedly limited) experience, anywhere south of the latitude of the Arkansas/Louisiana state line will have at least some parks open year-round, anywhere north of there will close for the winter. DeGray Lake Resort State Park at Bismarck, AR closes for the winter the end of Thanksgiving weekend (but puts on a fine Thanksgiving buffet just before that; highly recommended). Safe to assume most places north of there also close for the winter.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-12-2013, 03:56 PM   #12
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
We don't do snow anymore, we are full time Florida residents, the occasional trip north is only in warm weather, our normal travel is 200 miles a day but when pushed for time or weather window we can double that. so a trip south with the given advice of a couple of days clear weather should be easy to do. We are far enough south that winterizing is to make sure the water lines are empty by Jan until Feb. However, when we have a mild winter with a short freeze time. a couple of hours, I don't worry about it. Land Yacht's have freshwater tank under the bed, and some protection of holding tanks but they are under the chassis, if I lived north I would either insulate or have a thermostatic controlled heat wire installed near the valves, the waterlines are inside so running the furnace would do it. Furnace does use 12v and uses a lot of battery power to run all night so plug in or running generator would be prudent. My problem is that if the furnace is on but not running due to low thermostat setting when I park, I have been surprised by going out on a cold morning and hearing the furnace running, so I now make sure it is in the off position.
Old 07-12-2013, 04:02 PM   #13
Youngstown , Ohio
Speaking of snow...and sorry to jump in on your thread but I just saw where someone said during a big snow last year, they went up on top and covered their vents. Never heard that before and wondered if that is common practice? Also live in Ohio.
Splinter is offline   Reply With Quote
Old 07-13-2013, 05:16 AM   #14
Rockford , Michigan
Images: 12
Funny to be discussing snow in July!
But, to answer Splinter....I don't remember a discussion of covering the vents from the outside. Several suggested covering them with an interior insulating material...name escapes me, but it looks like shiny/metal bubble wrap.
