Old 06-01-2018, 12:53 PM   #1
Houston , Texas
Motorhome engine conversion
Been looking to buy 345/325. Came across a 1984 unit whereby owner suggests it was originally diesel then converted to 454 before he purchased. Was used by Dometic as a marketing tool for their products. I was then told by an airstream pro that a direct conversion from diesel to gas 454 is not possible- to avoid this unit? HELP... is this correct - do I need more info. Please and thank you!
Tubby
Tubbydog is offline   Reply With Quote
Old 06-01-2018, 01:43 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
That's pretty difficult to believe on many different levels. Not to say it didn't happen, people do some crazy things. But that one is pretty hard to swallow. A factory diesel is significantly more desirable I would venture. Did they mention any reasons why.
mayco is offline   Reply With Quote
Old 06-01-2018, 01:56 PM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Run!
SteveSueMac is online now   Reply With Quote
Old 06-01-2018, 02:26 PM   #4
Houston , Texas
He said the gas tank had some markings regarding diesel and the previous owner told him. Clearly who would replace diesel with gas... makes no sense.
Old 06-01-2018, 04:07 PM   #5
Several years ago I dismantled a 454 powered 1986 345 and the tank was marked diesel. My personal opinion is the one you're looking at came from the factory with a 454. I'm 99% certain the tank was original to the coach and I know the engine was as well.
I would also sank bunk to the Airstream Pro about the swap. The P30 chassis will accept a 454 or diesel with no issues.
Old 06-01-2018, 05:13 PM   #6
Houston , Texas
Thanks. It had occurred to me that the owner is wrong and for some reason the tank had diesel markings. I was going to get the VIN and call Airstream to look it up. The unit is nice enough, 100k miles, new fridge, heat, tires, upholstery, carpet- dash compressor,, wine cooler- under $20k. One softball sized dent left of window left of door- And itís painted white, black and maroon.. after reading this forum it appears the dent can be addressed with a special technique. Iím seriously considering if correct that it was always a 454.
Old 06-01-2018, 08:38 PM   #7
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
My understanding is during that vintage all Airstream chassis were delivered with a 454 Chevy and people at Airstream removed the 454 and adapted an Isuzu diesel to the Chevy transmission and chassis. The conversion is pretty obvious on my 280 diesel built in 1982.
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Losing engine elec. engine dies while driving ccgartman Airstream Motorhome Forums 4 12-10-2011 08:46 AM
Trailer to Motorhome Conversion! Whoa! ViewRVs Airstream Motorhome Forums 10 08-16-2011 03:23 PM
1982 28' Airstream Motorhome Bus Conversion InvernessGuy Classic Motorhomes 1 04-12-2009 11:44 AM
Propane Tank For Engine Conversion Chuckles Classic Motorhomes 7 03-16-2009 05:16 PM
Engine conversion? billhabing Mechanics Corner - Engines, Transmission & More... 2 02-26-2004 08:46 PM
