Old 12-01-2004, 06:30 PM   #1
bcb79mh
1979 28' Airstream Excella 28
Nashville , Tennessee
motorhome air bag modification?
1979 28' motorhome - considering adding a 3/4 to 1 inch flat steel spacer beneath the rear air bags to increase ride height, unit is working correctly now, has anyone tried this?
bencbailey is offline   Reply With Quote
Old 12-01-2004, 08:52 PM   #2
jim8860's Avatar
Send a message via AIM to jim8860
I can see any problems doing that,but I do ask why?.Thats is one of the reason to run air bags you can adjust the ride hight.
jim8860 is offline   Reply With Quote
Old 04-21-2005, 07:36 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
(I am adding to this thread as the new thread I posted did not work)
I have a manual fill schrader valve I put in when I removed the compressor last year. It worked great all year and held air in the bags a long time. The ride was much improved.
Now I can't get air into either of the bags. I have not found a leak yet so I figure a line must be clogged.
Can I take the air tank out of the system? Its old and probably rusted inside. Is there any reason to leave it in since I don't use a compressor onboard?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-21-2005, 12:12 PM   #4
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Alan,
Does yours have a leveling system at all that transfers air from one side to the others?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 04-21-2005, 01:18 PM   #5
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
The only way I can post is to "hi-jack" so: any of you switched radios in your trailer? I would like one with a CD stack.
Please tell me what you did/bought.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 04-21-2005, 06:07 PM   #6
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Alan,
The tank acts as a buffer on your bags. If you remove it then there will not be anywhere for the bags to draw more air if they are down. The leveling valve will open and nothing will happen.
You can run like this, but I would check the bags each day prior to leaving and make sure they are full.
The Air Ride system is supposed to adjust as we load and unload the coach. Mine come on after I fill the fuel tank, or if I have filled the water tank. It will dump air as needed when I burn the fuel or dump the tanks.
Tanks can be had for a small price on Ebay, so can compressors if you keep looking. If you add a compressor be sure to get one rated at Minimum 25% duty cycle to assure a long life.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-22-2005, 05:18 AM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I do have the levelling system and since I don't have the compressor I guess I was thinking that the tank was not doing anything. I think I will pull it, and see if I can clear the lines then replace the tank.
I can't go with the compressor right now too much other stuff on my plate. My ride was so nice all last year, its not horrible now, but the bags are too low to do their best job.
AIR #005
retired!
Old 04-22-2005, 11:34 AM   #8
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The first thing to check is the check valve on the output of the tank. If it is clogged that is where all of you troubles could be.
On thing that the owners manual says to do, and I know I do not do it, is to purge some of the air out of the tank each month. The schrader valve is normally at a low point and the condensation that will build up in the tank eats it from the inside out. Your problem may be that the valve is just gooked up form rust and crud
Brett G
Old 04-22-2005, 11:36 AM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Will do. I will check this out.
AIR #005
retired!
Old 04-22-2005, 09:12 PM   #10
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
If you have a check valve at the output side of the tank, How can the tank act as a buffer? The check valve stop the air from going back into the tank. You lost Me on this one.
alfalsetto is offline   Reply With Quote
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
air bag compressor zamboni Mechanics Corner - Engines, Transmission & More... 2 11-19-2002 10:38 AM
Motorhome Mechanix Motorhome Mechanix Airstream Motorhome Forums 1 10-27-2002 12:17 PM
Heater and Air Conditioner jberndt Airstream Motorhome Forums 2 10-22-2002 07:45 AM
Ram air Kit rdm Mechanics Corner - Engines, Transmission & More... 0 05-12-2002 09:04 AM
