View Poll Results: Is daqsh Air needed in a motorhome?
Yes
22 |
81.48% |
No
5 |
18.52% |
02-18-2008, 09:43 PM
Motorhome A/C or no A/C
This question is for Motorhome owners, how often do you need your dash A/C?
I am going thru my engine bay doing headers and a new intake etc... and am removing smog equipment and all unnecessary items and doing a general cleanup.
And even though everything is there for A/C, It needs to be charged and have a new drier etc... I am considering just removing the dash A/C and just using the roof air and generator when A/C is needed.
Plus I like the room in the engine bay when there is no A/C.
Let me know from experiance if you feel dash A/C is needed.
02-18-2008, 09:46 PM
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
, Alabama
I've always been very happy to have it each time it gets turned on.
Hot sunny days in traffic, with Sun coming in thru the front can get sweaty in the front seats.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
02-18-2008, 10:19 PM
_
i could (and did) live with
no ac in the house...
no ac in the car...
but i could NOT imagine going without the dash ac in the moho...
i never found the roof ac to be very good at cooling the FRONT area of the moho while in motion.
and opening windows at 60+ mph didn't work well either, so a small 12v fan on the dash was a nice extra.
cheers
2air'
02-18-2008, 10:25 PM
1985 34.5' Airstream 345
Tujunga
We don't use ours very often, but it's good to have when you need it. I wouldn't remove it if I were you. Ron
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
02-19-2008, 06:06 AM
2017 27' Flying Cloud
Altoona
Gotta Have It - I Suguest You Upgrade To The New Freon System While Your At It.
02-19-2008, 06:33 AM
Naples
Yes!
When I full-timed in my 40' Monaco Dynasty diesel MoHo, the dash air was on almost all of the time! In fact, we used to run the front roof A/C with the generator a lot while zipping down the road too!!!!
lewster
02-19-2008, 07:00 AM
I am seeing a clear trend developing that dash A/C is a keeper.
I sure do like the extra room and the looks without it, but will reconsider removal based upon the advise given so far.
RichardT
02-19-2008, 08:08 AM
The Hawk's Lair
BACK WOODS
Here's the clincher. Without it on those rainy days your windhsield will fog up and the roof air won't help a bit. We use our all the time.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
02-19-2008, 08:19 AM
I had it in my Argossy, but on one trip from LA to Vagas it was 130 degrees out side and with the size of the windows the a/c did nothing but add heat to the engine. Since the a/c was useless when I needed it most, I decided to just remove it all. Now the engine runs a bit cooler, getting direct air to the rad, and it neetend up the engine comartment.
02-19-2008, 08:36 AM
1984 31' Airstream310
Central
, Ohio
We could not live without dash A/C (and have been very, VERY uncomfortable when ours has gone out before). Roof A/C will not keep up with all climates (we live in and travel around the South) and dash air is a must. And as cooperhawk says, it is the only way to defog those huge windows without a squeegee!
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
02-19-2008, 02:25 PM
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia
, Alabama
We use ours all the time in our 345. There is nothing better than a well operating R-12 system!
Good luck, Rob
02-19-2008, 02:48 PM
1991 35' Airstream 350
Windsor
, North Carolina
Dash AC
So:
Since the Zeppelin is sitting in the cold--
Since it isn't going to be used for another month or so--
Since the Dash AC has been kaput since we've had it--more than 2 years
It might be a good time to do something about getting it to work.
Problem is, I'm a complete idiot....about AC systems. Is there a decent manual out there somewhere that is usable by the average shade tree wrench-turner, for these or similar systems??
I don't expect parts to be a problem--it's figuring our which parts.
Rob
02-19-2008, 03:08 PM
Las Vegas
, Nevada
we are in so. nv. and in summer use front & dash air constantly while using the 345, even nightime driving.
02-19-2008, 04:59 PM
Altoona
P-30 chassis's are pretty simple and any licenced A/C shop can fix you up. Can't do it on your own. Get several estimates - Good luck!!
02-22-2008, 01:21 PM
1995 30' Excella
Bowie
, Maryland
I clicked back and forth between "Yes" and "No" several time before settling on "No". Why? Because my dash air conditioning hasn't worked since I bought the van nearly 3 years ago, so it obviously must not be necessary.
That said, I WOULD like to get it working, but it's at the point where it pretty much entirely should be replaced - new compressor, several lines leaking, accumulator, etc. Expensive even if I do the work myself and have a shop test and fill it.
The other thing is that I would still need the generator and rooftop air, because I travel with my cat, and when I stop for breaks I don't want it to get hot in there (and I'm not sure the dash air would be enough to cool the entire B-van down). However the cab area does get significantly warmer than the rest of the camper, even with the rooftop air running and blowing air right at it. I'd like to get some of those 12-volt clip-on fans to help that situation.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
02-25-2008, 01:53 PM
2000 35' Land Yacht XL w/slide
Vermilion
, Ohio
I would keep it
1)Re sale Value
2) What if the roof AC dies (I know nothing breaks on these things But what if ?)
3) Running the AC mode to defog winds
4) Short trips
5) When your low on fuel
02-28-2008, 06:04 PM
2005 25' International CCD
Leesburg
, Georgia
the roof air helps keep passengers and my neck cool, but sure would like the dash air to work too, it may be a simple fix or it could cost. the dc fan i have up front doesn't blow strong enough! am considering an auto repair course at a local tech.
i'd say keep it unless you plan to only travel north of the 'bat cave.'
03-01-2008, 07:07 AM
1984 28' Funeral Coach
Belleview
Richard, having removed mine I can attest to what everyone else has said.
When running down the road in the direction of the sun you're driving a greenhouse.
On the positive side you've got the a/c unit just behind you on the roof.
I'd keep the dash a/c and go electric cooling fans for more room in front of the engine. Give the engine a break on turning that big cooling fan.
Also for those who don't have one or two of them I recommend dash mounted fans for cooling the body! When the front end gets hot I turn on the body fan and get a lot of relief. It's quite dramatic.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
03-01-2008, 07:16 AM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
I use mine, being a 20', it cools the rig with out running the Armstron AC
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
03-02-2008, 11:12 AM
1990 33' Land Yacht
Jacksonville
Dash Air
Richard,
I removed mine before our trip last summer, and never missed it. Engine ran cooler, and I am led to believe that genset/roof airs use less gas. I do have small 12v fans in front to circulate air, and the defrost still works on rainy days.
For us, not having dash air has worked well.
Safe travels,
FRank
Frank and Susan Davis
Jacksonville, Florida
33' 1990 Airstream Land Yacht: Edelbrock, Banks, Gear Vendors, MSD, Taylor wires, Super Steer bell cranks, Bilsteins, Roadmaster sway bar, Safe Steer, Pressure Pro, Crossfire, Bigfoot levelers, Rickson 7.5" rims & 245/70 R19.5 Bridgestones on steer axle.
