I still haven't managed to find time to photograph the plug leads (sorry - wires) yet; but believe me some were bad!
Here in the UK Unleaded is rated at 95 octane so after running with the timing set from the USA since we had it, and with the help of a mate who knows about these things, we set the timing (from underneath) from 14.5 degrees BTDC as it was; to a retarded 8.5 degrees BTDC. (UK Owners note)
Wow! what a difference! It starts easier, is quieter and above all runs like a 7.4Lt should, I even have to use the brakes to keep the speed down!
Fuel consumption? well I think it is getting better all the time. We have just toured the Cotswolds in England, then on to Ireland (North and South) and a few places in Wales on our return. .... And I thought we in Dorset had small roads.... you should experience those in Northern Ireland and Wales - I still cringe at the thought.....
Then it is one final fill up to hopefully arrive at an accurate figure of fuel consumption, but it is looking good.
I have been advised that the Qjet uses the choke continuously, so by disabling the choke altogether, I am told, am reducing the efficiency of the running. Do you think it is right to be thinking of a replacement carburettor before the Engine LPG conversion?
It frightens me a bit that I may be contemplating using the choke again following the experiences in the past.
Any comments on this I would be grateful to hear
