Old 04-29-2010, 04:52 PM   #127
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
Boy, and I thought I did good coming back north from New Orleans to Oklahoma with a 30mph tail wind, running about 63mph, no toad and for the first time in 55,000 miles the Silver Bullet got 8mpg (7.6, 8.0, 7.4)
mel
choctawmel is offline   Reply With Quote
Old 04-29-2010, 05:38 PM   #128
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Bess gets 14.9 mpg, burns no oil. What a classy engine that Izuzu is!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 04-30-2010, 07:18 AM   #129
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
I have this lustful desire to find a late model N-series Isuzu with a Turbo/Intercooled Diesel 4HK1-TC and the 6-Speed Automatic AISIN Double Overdrive Lock-Up, 2nd-6th.
I think it would pull my 16,234 pound Silver Bullet and 2300 pound toad right down the road. Just bet I'd be getting twice the mileage and with 441 lbs/ft torque, I'd have more power too.
But then, my bucket list is leaking.
mel
Old 04-30-2010, 08:27 AM   #130
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
My mileage had dropped off a bit, so last month we adjusted the valves and gave her a good going over.
I used to get 16 mpg regularly, but it had dropped to around 12. Now I expect it to go back up.
Valves on an Isuzu diesel should be adjusted every hundred thousand miles or so. Some were too tight and some were loose.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 04-30-2010, 12:42 PM   #131
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I wonder why such a difference in gas mileage on the older style gas MH, than the fiberglas style? Most of newer body style owners claim they get 10 mpg. I personally get that on my 1993 when not towing anything. On my last trip from Michigan to Flordia I averaged just over 9 mpg and that wasn't always driving in overdrive pulling a ranger pickup. I am surprised to read so many older style Airstreams getting so low of mileage.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 04-30-2010, 02:01 PM   #132
Mike Leary's Avatar
Images: 11
Good point, I had Bess adjusted a few years ago and was amazed at the difference in the tolerences.
Old 05-01-2010, 04:05 PM   #133
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
The 454 in your MH is a newer generation than mine; Your trany has a lockup converter, mine don't; you have an overdrive, once again mine don't.
I need to upgrade! I see GovSales has a dodge 3500 w/Commins and AT on sale. The bid now (it I read this right) stands at $5300. Only problem is, it's in Whitmire, SC and I'm in Okla. Hard to look and see what it's like from here. Wonder if it's the 12 or 24 valve motor?
mel
Old 05-01-2010, 07:07 PM   #134
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Your mileage may vary, has never been truer than in motorhomes. The early AS moho on a P30 chassis had a 3 spd transmission with a final drive ratio of 4:56 or at best 4:10.
To compare this to the modern AS with fuel injection, 4 spd overdrive and the Workhorse chassis is like comparing apples to apple cider.
Terrain and driving habits count for a lot too.
The ROI of the diesel swap is all about mileage vs. fuel cost + conversion. I drive a lot of miles and can't make the $'s work.
Now with the addition of the GV I'm in the 11.5 - 12 mpg range and happy with the reduction in RPM's and cabin noise.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 11-20-2010, 10:16 AM   #135
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Motor Home Mileage, Diesel, Gas, Records
I continue to see a lot of discussion re- mileage, and some of that with coffee shop napkin references. I also do a lot of strategy planning on the back of napkins, and then loose the info, when that pretty waitress comes and cleans the table.
If you are going to buy/own a motor home (any vehicle for that matter) and are keen to discuss the merits of your asset, then it is important that you develop a system to record all the details.
For those who don't want to be bothered making up an elaborate fuel record diary, just purchase a spiral bound note pad at the local store, and use it like a travelling diary. The spiral pad folds easy and stays together well, and when full, buy another, and store the old one for future reference.
I use one, and record everything, with mileage, date, so that it can be referred back to if desired. (eg. long story/short - going north, we hit a frost heave in the Yukon and went airborne in 2008. After gaining control, I recorded the odometer to watch for it on the return trip. Yep, it was still there unmarked, and I should have had the spouse and camera ready to take a picture of a pickup/trailer in the air, fishtailing toward us, as he headed north. The picture would have won any action contest. Because I missed that opportunity I have since installed a w/s mounted camera that I can operate via the brake light circuit.)
The point is that your memory will fade in time, but if you have it recorded, you can go back and relive each trip highlite/lowlite, with accurate information.
Professional drivers are required to record "Daily Pretrip" books that are available at any truck stop or service center. I also use these books to record the required info, + location AM/PM, and vehicle related info, updates, etc.
If you ever are involved in an accident, and have poor, or no records of your maintenance, you could be in trouble. Record everything, and in the long run it will pay dividends. Even on sale of a unit, the next buyer will be thrilled to have your maintenance records to refer to.
Dave
Old 12-24-2010, 07:01 AM   #136
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Hello Glen, when did you install the GV. system ?
did you do the install Yourself ?
thank You and Merry Christmas
John H. is offline   Reply With Quote
Old 12-28-2010, 08:20 PM   #137
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
Originally Posted by 87MH
.jpg file
To go back to $1.38 a gal. Lol.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 12-29-2010, 11:41 AM   #138
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
I remember pulling the back seat out after someone rode in my car to find gas money. One thin dime would buy 1/2 gallon of gas. I'll still pickup a penny.
Old 12-29-2010, 07:46 PM   #139
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Most I remember when I was 16 in 1989 and gas was .74 a gallon.
Athens GA
Old 12-30-2010, 03:55 AM   #140
Images: 13
when I was 16 gas was a Quarter a gallon
