Old 08-28-2013, 06:01 AM   #15
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
Cab Fresh inside (smells good to me...bad to mice)
Moth balls outside on the ground & a few in the jack base plates (smells bad to all)
Remove all food after each trip
Don't store paper towels or tp inside (nesting material)
Worked for us! no mice in almost 2 years.
We trapped several (5 or 6) inside before we decided we we luring the mice in with the p-nut butter in the traps...decided we preferred to keep them out! The cab fresh & the moth balls seem to do the trick.
Schools Out is offline   Reply With Quote
Old 09-15-2013, 06:49 AM   #16
la nomade's Avatar
2018 22' Sport
stanfordville , New York
first,leave no paper towel or kleenex boxes or toilet paper or soap....i fill a tall plastic bucket with about 6" or more of water...i put peanut butter 2'or3'inside just below the rim...then a small ramp up with a nail at the top so it does not slide..the mouse go up,try to reach the p.butter and fall in the water and drown....I empty the bucket and refresh ..it works great...at some point they stop coming in....plus i do put peppermint oil here and there in drawers etc....Living in the woods ,its unavoidable,they do come in to find a cosy place to spend the winter and have babies.....Plus the fact that i have a minn.Pincher helps...good luck!
la nomade is offline   Reply With Quote
Old 09-16-2013, 06:38 AM   #17
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Ya, My house is surrounded by woods as well. Seems like a constant battle to keep them under control. I found a product called "Fresh Cab" that seems to be working. Keeps the MH smelling clean too.
92landyacht is offline   Reply With Quote
Old 02-02-2014, 07:46 AM   #18
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Mice intrusion
QUOTE: "Just can't seem to see how they're getting in and how to stop it. Any suggestions on how to stop this rodent issue from running away with my MH?"
92landyacht,
When I removed the rear nightstands on each side of the bed for access to replace turn signals and backup lights with LED bulbs - I discovered Airstream's poor design (not only for access to the bulbs) but in body construction. There are big holes open directly to the outside, making it very easy for mice intrusion and nesting underneath these cabinets. No insulation in that area either. On one side I was able to use Styrofoam attached to luan to block the hole, but on the fresh water inlet side along with the generator transfer box - all the wiring- it is impossible to block hole efficiently. I will try to post pics.
ID:	204785   Click image for larger version
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 02-02-2014, 03:26 PM   #19
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
I screened all the openings (including the tube steel in the front end), and put dryer sheets all over the place during storage. Have traps outside. Have never had a mouse in six years. Maybe just correlation not causation.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
