Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 12-04-2012, 10:47 AM   #1
MH vin - which number for DMV
Sometime next year I plan on licensing and titling my Argosy motorhome in Kentucky. Currently it has an Arkansas title which I obtained back in 2009 prior to transporting the MH to Kentucky. The motorhome is not road worthy as yet.
The Argosy was purchased from a gentleman in Eastern Tennessee although he had never put the motorhome in his name. I didn't pay any attention when I titled it in Arkansas and today when I glanced at the title I noticed that the title had the Airstream VIN on it and not the GM VIN. Is this normal? I would have thought the GM VIN would be the one to use for obtaining license plates.
Am I missing something?
1975 24' Argosy Motor Home
Old 12-04-2012, 12:01 PM   #2
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
My Interestate is titled using the Sprinter VIN. I think this is how it's normally done.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 12-04-2012, 12:32 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I went through this almost a year ago. My Interstate is registered using the Mercedes VIN, but it's still listed as an Airstream Interstate. I had two Manufacturer's Statements of Origin, one for the Sprinter Van, and one for the Airstream conversion. But a converted Mercedes is still a Mercedes, as far as registration and VINs are concerned.
bkahler, you already have a title that uses the Airstream VIN, and most DMVs will put the same VIN on the registration as on the title.
But the definitive answer probably is, use the one that's on the dashboard data plate. For any legal issue (like if it's stolen or broken into), that's the VIN the police will use, so that's the one that needs to be on the registration.
When you register the vehicle is the perfect opporunity to get the title VIN changed, if need be, because when you register in a new state, you'll have to surrender the old title, and you'll get a new title from the State.
Old 12-04-2012, 02:42 PM   #4
My biggest concern is the hassle I am expecting when I try to register the motorhome in Kentucky. For motorhomes it's a two step process. The first step is to get a Fire Marshall to inspect the vehicle and provide a signed form indicating the motorhome passes his inspection. I believe that form has a VIN location on it. I'm not sure which VIN he needs to put on the form. I would guess they would want the GM VIN. Once I have that form signed I then have to go to the sheriffs department and they do a vehicle number inspection to insure that it matches what is on the existing title from Arkansas.
What I really need to do is call the Kentucky DMV and ask them which VIN they expect to use and if it is the GM VIN then I will need to proceed from there.
Duh, it just occurred to me that when I get home tonight I can look at the title for our 310 motorhome and see which VIN it registered under
That will at least answer one of my questions.
Old 12-04-2012, 05:44 PM   #5
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I can bet the sheriff's VIN inspection will straighten it out. The VIN is a standard 17 character number used pretty much worldwide. The Airstream number will not show in anybodies data base. As long as the sheriff can find both numbers and verify one of them matches your old title he can indicate that on his paper work and see that the correct number is on the new title.
On old vehicles, like back in the 50's and older, especially foreign vehicles they had all kinds of weird numbering systems and you can have some real fun at the DMV. It pays to bring some factory and restoration manuals with you to try to instruct the inspector as to what a proper number is supposed to look like.
Cheers, Dan
Smartstream is offline   Reply With Quote
Old 12-04-2012, 06:24 PM   #6
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
iirc, the 17 character VIN was adopted here in North America in 1980 for 1981 model year vehicles, so don't let anyone get hung up on that little technicality.
fwiw, Brad, we titled and registered registered our coach with the GM VIN, the same as the previous title.
also, we still have not located the Argosy plate, so we don't even know what that number is!
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
jm2 is offline   Reply With Quote
Old 12-04-2012, 06:39 PM   #7
Out of the 10 or 12 odd vehicles that we own I doubt if more than more than 4 of them have 17 character vin numbers Personally I like older vehicles.
Which makes sense.
On my 74 Argosy the Argosy plate is on the left vertical upright about midway in the opening when you're looking in. I don't know if they 77 models had the same construction. By 1984 Airstream had definitely changed the structural configuration of the supporting frame work. The GM VIN plate is the square plate in the upper center area.
In the following pictures you can see where each is located.
ID:	173908Click image for larger version
Old 12-04-2012, 06:52 PM   #8
Cheers, Dan
Dan, good points! I'm going to call the sheriff tomorrow and see if they agree with what you're suggesting.
My TR4 has been titled by the body number and not the vehicle commission number which from a Purist point of view is a no-no. To me its not worth trying to correct the issue. As long as I can drive it I'm happy
Old 12-05-2012, 11:37 AM   #9
Well I just had a refreshing conversation with the Kentucky DMV clerk. I described to her the problem with the motorhome having two VIN numbers and that Arkansas had used the Airstream coach VIN instead of the GM VIN.
She said I had a couple of options. The first was to go back to Arkansas and get them to change the title to show the GM number instead of the Airstream number, OR I could bring the motorhome, title and proof of fire marshall inspection to the Sheriffs office and have the Sheriff look at the Airstream number.
She politely said sometimes a person can provide too much information and in this case the less said the better. She then said, politely I might add, that I should just keep my mouth shut and hand the Sheriff the paperwork and point to where the Airstream VIN number was located.
I think I can do that
Hopefully this issue will just be a big worry that amounts to nothing.
Thanks for the replies,
Old 12-05-2012, 12:32 PM   #10
Motorhomes from Airstream do not have 2 serial numbers, so to speak.
One number, is a chassis number.
The second number, which is on the vertical bar under the hood, is Airstreams serial number.
Why 2 numbers ??
A company such as Airstream, might buy say, 100 chassis.
However, they might have only used a part of them, for that production year.
Then, the following year, they used some more of them, etc.
Accordingly then, the "true" serial number which contains the year model, is what should be used.
The chassis number, which also contains the year, could be used the following year and quite well the year after that as well. That would not be a good way to state the year of the coach.
As an example, a chassis dated 2000, could be used in 2000, 2001 and even 2002 or later.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-09-2012, 08:09 PM   #11
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
The GM forward control chassis that our Moho use are incomplete vehicles. They can not be used as a vehicle with out the part that Airstream made. So you should title the Airstream vin. My 1991 350 LE has a 1990 chassis vin. As usual, Andy is correct. Steve
t7389sg is offline   Reply With Quote
Old 12-14-2012, 05:17 PM   #12
Steve, what I'm finding is it seems to be a mixed bag as too how they are titled. Some are using the chassis vin and others the Airstream vin.
When I'm ready I'lljust going to present the vehicle for inspection and if they don't like what's on the title it will get sorted it out at that time.
Thanks!
brad
Old 12-23-2012, 04:24 PM   #13
WineStream's Avatar
2023 30' Globetrotter
Pleasanton , California
Images: 24
There's been enough ambiguity added here, but what the heck, I'll add more. I bought my moho in PA and brought it to OH, so I had the lovely inspection to go through, too. I will say though, OH is really lax when it comes to vehicle stuff. The BMV does the "inspection" which is really just one of the clerks coming out to the parking lot with a notepad and writing down the VIN. They really have no legal authority or training. In my case, she said, "where's the VIN on this thing?" and I showed her the chassis VIN under the hood. Why? Because I thought that a metal plate riveted to the the body/frame was a better choice than a typewriter-written sticker on the dash. I verified against my title that this is indeed the VIN that it was titled under (chassis VIN). Apparently this is what the PA title had on it as well because the title office didn't question me on a VIN miss-match.
WineStream is offline   Reply With Quote
Old 12-29-2012, 08:08 PM   #14
JudgesArgosy's Avatar
1974 24' Argosy 24
somerdale , New Jersey
Brad,
It wasn't till I came across this website that I realized I had two VINs for my Argosy. I simply handed DMV the signed title with my money to register it here in Jersey. My title shows the GM # but I'm sure they only care about the registration money.
Matt
JudgesArgosy is offline   Reply With Quote
Old 01-29-2013, 06:10 PM   #15
buckwheat's Avatar
1987 34.5' Airstream 345
Hendersonville , North Carolina
Sorry Brad, I know this thread is over two months old, but the definitive answer to your dilemma is provided here for the benefit of others with similar issues. According to this Airstream document on the NHTSA DOT ftp site, ftp://ftp.nhtsa.dot.gov/mfrmail/ORG4157.pdf, the chassis manufacturer VIN must be used for motorhome registration, for AS trailers use the Airstream VIN.
BubbleHead Fred
"Underway is the only way!"
buckwheat is offline   Reply With Quote
Old 01-29-2013, 08:09 PM   #16
Fred, thanks for the info! At least I now know what the legal requirement is. Hopefully sometime this year I'll actually be able to take the Argosy to the Kentucky DMV and get it titled and licensed.
One can dream anyway...
Old 01-29-2013, 09:02 PM   #17
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
one would think that would take care of it .
my 79 was titled with the Airstream Vin
my 87 was titled with the Chassis manufacturers Vin, which was an 86, but the Airstream Vin was 87. DMV wrote 87 in the title, even with the insurance company saying its an 86.
so......
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 01-30-2013, 10:15 AM   #18
I'm just going to take all of my paperwork to the DMV and trust that everything will work out.
Yeah right, like that's gonna happen
Old 01-30-2013, 08:58 PM   #19
Airstream Driver
1994 30' Excella
Images: 49
Easy in your case, it should be stamped right on the side of your shiny door, hahaha
AIR #13
Old 01-31-2013, 05:27 PM   #20
That might be appropriate, there will be enough 1986 345 parts on the Argosy that I could probably just stick the 345 vin plate on and be done with it
