Old 06-27-2013, 10:18 AM   #29
kdinnar's Avatar
2017 27' Flying Cloud
2014 25' FB Flying Cloud
2013 23' FB Flying Cloud
Boothbay Harbor , Maine
I've loved RV'ing for many years. Like many folks, I started tenting, then moved up to pop-ups (my last one had a built in shower and toilet), then a 25' and a 30' travel trailer. Next came a 30' motorhome. We just bought a new Flying Cloud 23FB.
As others have said, there are pros and cons for each.
The MH was great in many ways...you can set up very fast and it has all of the conveniences even as your are driving. My wife was ill once while traveling and was able to lay down in bed, while I drove. Our 2 dogs loved the space and freedom.
The big downside of the MH was parking. We like to sightsee and parking in many areas is impossible. The first year we rented cars, but that was a hassle. They we got a tow dolly to pull our Jetta, but hooking up was a pain...on the ground and in the rain. Finally we decided to trade our cars to get a Jeep that could be flat towed. Then you have to set up the car with a hitch and brake unit. It work great, but was a big expense. The car towed very well, but now you're driving a very long unit and you can't back up unless you unhitch the car.
We also had to travel a long distance to get the MH serviced as it required a large truck garage. Then you have an expensive unit depreciating even as it sits and you aren't using it.
So we decided that a TT was better for us. Towing the Airstream trailer is much easier that it ever was for me to drive the MH and attached car. We also feel that it will hold it value better. We pull it with the car we use everyday, which gets serviced at our local car dealer.
Hope you find the one that suits your needs the best!
kdinnar is offline   Reply With Quote
Old 06-27-2013, 03:12 PM   #30
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Suzuki toad
Originally Posted by choctawmel View Post
I guess I should throw my 2 cents worth into this thread.
I've had 4 different pull trailers and 4 different tow vehicles. Then I started keeping track of expenses: insurance, tags, taxes, gas, mileage, repairs. This was back in the 55 mph days. Towing- 10 mpg; running around- 7.5 mpg. I didn't need the big 454 3/4 ton Suburban but to tow the trailer. It sat, so was always something to fix. So, I had two tags, two to insure, and they sat in the yard. If you wanted to unhook and go sight seeing along the way I had the pain of hooking all that junk back up to go on.
Then I got my 1st MH (6 mpg) and I towed my Subaru 4X4 that got 25 mpg. The trailer spell was broken. I still have one drive train to keep up and I can pull either the wife's Suzuki or my Miata. Takes me 45 seconds to hook or unhook and then I can drive around in a 30 mpg car. Not sure what my 'Silver Bullet' gets for mpg yet, I haven't filled her up since her maiden voyage after I rebuild the motor, plus she was only running on 7 cylinders 'cause the new plug wires will not stay on the plug!
And besides, when you pull up in a neat looking old AS motor home people come and visit, because most people have never seen one before.
Tell me more about your Suzuki toad or the Miata. I am looking for a toad to tow behing my 82 24' MH...it manual says it can tow 2000 pounds. What kind of car weighs 2000 pounds and it towable 4 flat? Thanks, paula
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 06-27-2013, 05:00 PM   #31
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I dug out my 2013 Motorhome Magazine "Guide to Dinghy Towing". Out of over 75 flat-towables, the lowest-weight choices are the Chevy Spark (2,269 pounds curb weight) and the Toyota Yaris (2,295 pounds curb weight). But that's all 2013 models only.
I don't have back issues of the annual dinghy towing guide, so I can't say what might have been on the list for prior years, that might come in under 2000 pounds curb weight.
One thing you might want to look into, if the towing limit is based on the hitch rating— and the GCWR of the motorhome is high enough— you might be able to upgrade the hitch receiver and get a higher towing capacity, as long as MoHo plus toad is under the GCWR.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-27-2013, 05:47 PM   #32
SteSpot's Avatar
1968 28' Ambassador
Spark and Yaris
I was hoping to find an automatic.....with a/c.......We have a 454 7.4 liter Chevy engine on a P30 chassis. What I can't find is the gear ratio. The hitch that is on the MH looks terrible so that would be replaced for sure....the MH itself weighs about 9500 pounds empty.....some people say that I could tow anything....I am not so sure...Airstream and GM are of no help....I have an automatic Subaru that cannot be towed....really like the looks of the Fiat...but again, it must be manual....about the only auto is the Fit......Thanks, p
Paula & Ed
Suite Spot
1968 28'Ambassador
Old 06-27-2013, 06:02 PM   #33
That's what I tow behind my Interstate, a 2013 Honda Fit Sport, automatic transmission. Towing equipment (baseplates, towbar, supplemental brakes) all by Roadmaster.
WBCCI #1105
TAC LA-4
Old 06-29-2013, 02:09 PM   #34
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
The '99 Suzuki 4X4 w/197,000 miles on it and has been towed an added 60,000 miles, has a neutral in the transfer case which means it's towable with a automatic transmission (wife can't drive a stick) It is about 2900 pound, but tows with eases with a brake buddy(or is it easy brake?) in it for stopping. I bought it new to be the toad and my bicycle would fit into it
My '93 Miata I rescued from a junk yard a couple years back and it weighs in a little over 1900 pounds. The times I've towed the Miata, I've had to stop and look to see if it was still back there (backup camera is on the fritz) because it has no effect on stopping or going. It's so short I can't see it out the back window.
I looked at the 'smart car' which is under 2000 pounds and towable, but couldn't justify a new car. I really wanted to find a 2 door Suzuki Sameri/Tracker or a Kanmann Ghia, or .... Well they haven't make a cool, lite weight towable car in some years, and then I saw this Miata sitting in front of a local junk yard. I took a gamble on it and it's turned out to be the funnest ride I've had since my younger days and a 1968 Camaro that I had to sell when I got drafted (Drafted?? Young people, what's 'Drafted' mean?)
choctawmel is offline   Reply With Quote
Old 06-29-2013, 02:31 PM   #35
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Chevy Sonic
Have you looked at the Chevy Sonic. It's light weight and the automatic trans is towable 4 wheels down. That is what I tow and it works out great. Nice little car to drive as well.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 06-29-2013, 03:41 PM   #36
Reports differ on that score. I remember reading somewhere that— due to the way the front end is aligned (caster/camber)— it won't tow unless you bungee-cord the steering wheel in place; otherwise the front wheels try to turn left or right even when you're towing straight.
But I don't know that from personal experience; that's just what I've read.
WBCCI #1105
TAC LA-4
Old 06-29-2013, 04:14 PM   #37
2004 30' Classic
Hillsborough , New Jersey
motor home vs trailers
There were many good points of view in this thread. We too considered getting a motor home but we stuck with trailers ( our 5th trailer in about 40 years of "trailering").
The biggest disadvantage of a motor home that we see:
1. initial expense for a relatively new unit
2. gas mileage
3. parking
4. unhooking water, electric etc.if you want to go someplace after setting up camp
5. coming back late at night from a day out and having to set up again (many times in the dark)
6. if you pull a car along you can't back up very far
7. We can keep the trailer and buy a new tow vehicle if we need to
The advantage of a motor home In addition to what others have mentioned)
1. Everything is with you all the time.
2. The whole unit is cool in hot weather so when you pull into a campsite there is no waiting for the unit to cool down.
wolf146 is offline   Reply With Quote
Old 06-30-2013, 03:16 PM   #38
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
All I know about towing the smart is want the dealer said when I was looking at them. They offer the tow plate at the dealership.
When I towed the Subaru I had to bungee the steering wheel to the seat. It did well without..... till you're turning and hit a bump/dip and pebble... and the wheels would turn into the turn. After I'd started hearing the tires screaming: put 4-way flashers on and jump out, run to the car, turn the wheel straight, wave to the people behind me, run back to the motor home and take off. The wife's Suzuki 4X4 nor my Miata have that problem.
If only one could import the European diesel Smart Car before our government had a chance to screw it up: +70mpg and power (that's when the big boys tell me)
Anyone heard of anyone towing a Japanese 'mini' utility truck?
Old 06-30-2013, 06:21 PM   #39
Mel, are you talking about something like a small Toyota or Mazda pickup truck? If so, my dad towed a 1991 Mazda extended cab B2200 pickup with automatic transmission for a number of years. He had a drive shaft disconnect installed on the pickup that worked pretty slick. Pull the cable and it disconnected the drive shaft, push the cable back in and it would re-engage.
Old 07-01-2013, 06:46 AM   #40
You mean like a Suzuki or Mitsubishi?
ID:	189849   Click image for larger version
WBCCI #1105
TAC LA-4
Old 07-01-2013, 07:34 AM   #41
Are the Suzuki and Mitsubishi street legal?
It's my under standing that you can't flat tow something that is not considered street legal. I'm sure that varies by state.
Old 07-01-2013, 07:49 AM   #42
lewster's Avatar
Naples, FL , Hood River, OR
Look at the Mercedes Smart. A neighbor has a Winnebago Class B on the Sprinter 3500 chassis and just got one as a toad........very light and tows well (according to the neighbor.
