Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 01-28-2015, 11:32 AM   #1
1995 33' Land Yacht
Tempe , Arizona
Metal roofing
I want to convert the rubber roofing with an aluminum or stell roof. Who ever thought of rubber roofing should by whipped.
I own a 1995 Land Yacht 33 motorhome. Does anyone know who I should contact to buy the metal for the roof?
Thanks Lonnie Stepp
lstepp2 is offline   Reply With Quote
Old 01-28-2015, 08:00 PM   #2
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
I know, rubber roofs are short lived even it you wash, clean and coat them. I've repair ones that have 'torn' with cheese cloth and sealer. It only works short term as in every 3-4 months resealing is required.
choctawmel is offline   Reply With Quote
Old 01-28-2015, 10:47 PM   #3
1995 33' Land Yacht
Tempe , Arizona
Metal Roof
Thanks about the cheese cloth idea. I am basicall a lazy person. I would rather install a metal roof, like on a school bus or 18 wheeler trailers use.
Old 01-30-2015, 06:46 PM   #4
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Are you sure its rubber and not fiberglass? If it is original AS only used fiberglass.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
https://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 01-30-2015, 11:13 PM   #5
1995 33' Land Yacht
Tempe , Arizona
roof
I will have to double check. Sam's Club's repair people said it has holes in it and it needs to be repaired. I bought parts from a 1994 in Texas. Its roof had rotted off, rusting all the bows, and distroying the furiture. I saw photos of another Land Yacht in Canada on this sited that the same thing had occured. Leaving in Phoenix the desert generally blesses us little rain. However, this year is like 1979 when it rained all winter. I assume fiberglass will not leak?? However I did locate a place near San Franscio that sells rolls of aluminum roof for RVs. If it is rubber It will be replaced with Aluminum in the near future.
Thank-You
Aluminum roofing patch is discoloring 68vtsafari Ribs, Skins & Rivets 8 10-23-2010 08:23 PM
Removing Black Roofing Sealant???? kaferboy1 Roof 6 08-17-2009 09:46 PM
Peel & Seal Self-Stick Aluminum Roll Roofing 65overlander Ribs, Skins & Rivets 4 11-11-2006 11:15 AM
Southern Shine Metal Polish... trailertrash Cleaning, Stripping & Polishing 89 07-31-2003 04:33 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
