Old 12-02-2007, 02:50 PM   #1
Jim Casavant's Avatar
1985 34.5' Airstream 345
Mebane , North Carolina
Master Cylinder
I guess this is going to sound really silly but I have to ask...where is the master cylinder located on the 345 so I can check the break fluid level. Thanks
EVERYDAY IS A HOLIDAY!!
Jim Casavant is offline   Reply With Quote
Old 12-02-2007, 02:58 PM   #2
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
It is visable under wheel well of left front tire.
There is a metal shield with a cutout for topping off.
Turn wheel all the way, I don't remember which is best, left or right, but one helps you get up under there.
If you need to replace, that shield is easy to remove.
There are some good photos under motorhome repair forum.
http://www.airforums.com/forums/f160...ice-35807.html
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 12-02-2007, 04:21 PM   #3
Thank you for the info. Just checked...It looks good! I am selling my MH and I want to make sure it is all topped of for the new owner!
Master cylinder pjude Classic Motorhomes 2 07-23-2007 08:08 PM
Can you hook up a disposable propane cylinder? bhayden LP Gas, Piping, Tanks & Regulators 5 06-16-2006 09:10 PM
Brake master cylinder install Robfike Mechanics Corner - Engines, Transmission & More... 1 01-08-2006 08:37 PM
"Stuff" on Master Cylinder swebster Mechanics Corner - Engines, Transmission & More... 24 09-19-2005 06:25 PM
Master Cylinder Replacement will Airstream Motorhome Forums 3 08-16-2003 06:35 PM
