Originally Posted by RacingMan10
I have a 2016 Airstream Grand tour. The GFI keeps tripping. The Magnum converter/charger has power but will not turn on. This I know because the remote has power. None of the GFI outlets have power. Batteries are charged up and yes I'm plugged in to shore power. Any suggestions as to what is happening?
A couple weeks ago my inverter would not turn on. I thought “inverter failure” and ordered a new one.
It turns out that in the installation of my fancy America aluminum patch that we drilled through a wire that goes to an outlet and created a short circuit.
The inverter reacted far quicker to the short than the circuit breaker, which did not trip until I was hooked to more conventional power.
Do you have a short somewhere maybe, or is your inverter just failing? Hard to say from here, but some food for thought to keep you from replacing an inverter that is working perfectly like I did.
