Old 10-12-2010, 05:42 AM   #1
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Low Coolant warning light
Streamers,
I think I have found an answer to our goofy 'Low Coolant", and "Low Washer Fluid" lights. This weekend we will be taking the 345 out for one of our final short trips of the year, and will test the systems. I will be posting the details of our change after that.
So far both lights work the way they were designed.
Rob
Robfike is offline   Reply With Quote
Old 10-12-2010, 06:41 AM   #2
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
My light works, but at times regesters low when not. I think the connection might be loose or the terminals need to be cleaned with a file. Mine work 98% of the time, so haven't fooled with them yet.
raveson is offline   Reply With Quote
Old 10-13-2010, 08:07 AM   #3
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
My "Low Coolant" light flashes from time to time. I suspect it is the ground. Keep me advised please.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 11-02-2010, 05:19 AM   #4
Robfike's Avatar
Speedway , Indiana
Update...
I am still chasing bad grounds on these circuits. Stay tuned.
Old 11-02-2010, 06:14 AM   #5
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
low coolant light
This is just a stab in the dark based on my experience with the durmax engine. But if there is air in the system you will occasionally get the low coolant light. This usually happens when you flush the system and refill. There is actually a screw on the thermostat housing to bleed the air out. I know a lot of people say the system will burp and clear the air in a couple of hours after a drain or flush but others say they can not get the engine to burp and must bleed the air out. Just another possibility??
fltlevel510 is offline   Reply With Quote
Old 11-02-2010, 06:22 PM   #6
Robfike's Avatar
Speedway , Indiana
The probes are located in the overflow bottle. I think the circuit is just so sensitive, any resistance in the ground will throw it off.
Old 11-03-2010, 06:32 PM   #7
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
I had the 'Water in Fuel' light would come on now and then. I pulled the wire off the light and it very lite again.
mel
choctawmel is offline   Reply With Quote
Old 11-03-2010, 06:50 PM   #8
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
I just bought mine in Indiana and driving back to Athens GA it came on while climbing the mountains in TN. I was only going 45 mph pulling my 08 wrangler up hill. Haha. I did add coolant to the full line. I got back no problems. I flushed the radiator all seems good. The rear differential was sludge, changed that too.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 11-03-2010, 07:03 PM   #9
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I finally unplugged mine, AS is as infamous for grounding problems as Lucas in England was. I'd be interested in a fix, too, unless it means getting into the "rat's nest" of wires under the dash!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-09-2010, 09:46 AM   #10
Can't wait to hear Rob!
Both of mine are on!
Old 11-11-2010, 04:29 AM   #11
Robfike's Avatar
Speedway , Indiana
I hope to get back to work on this project this weekend or next week.
This week I have to take advantage of the great weather to finish a project for my dad & step mom.
Stay tuned!
Old 11-11-2010, 09:30 AM   #12
Good job Rob!
Looking fwd to hearing your solution, and smooth sailing on the side project!
Old 11-23-2010, 03:19 PM   #13
Robfike's Avatar
Speedway , Indiana
OK guys,
I have now officially given up on this project. The units I have installed just do not work. Like many other owners, I am just going to pull the bulbs out.
Old 11-23-2010, 04:23 PM   #14
Whoa!
Good effort Rob, but take a breather, open a cold beverage of your choice, and collect your thoughts, and post what you tried to do.
I have no clue how a pair of connections on the tanks becomes a lit bulb on the dash.. and I have several... with black electrical tape over them.
I did however read a long post in the trailer repair section about the tank level units that Zepplinium built, and whilst 95% of it went over my head, there may be clues there!
http://www.airforums.com/forums/f443...tal-58532.html
Low Coolant Sensor guy99 General Motorhome Topics 27 10-14-2013 10:47 AM
Low Coolant Sensor Mustangmatt Classic Motorhomes 5 07-13-2009 07:35 AM
Brake warning light tandemfish Mechanics Corner - Engines, Transmission & More... 3 04-25-2006 07:04 PM
Low tire warning info???? Orland Dewey General Motorhome Topics 0 11-04-2004 09:18 PM
How long should the Low Coolant light stay on. rdm Mechanics Corner - Engines, Transmission & More... 7 06-01-2004 09:04 PM
