10-12-2010, 05:42 AM
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia
, Alabama
Low Coolant warning light
Streamers,
I think I have found an answer to our goofy 'Low Coolant", and "Low Washer Fluid" lights. This weekend we will be taking the 345 out for one of our final short trips of the year, and will test the systems. I will be posting the details of our change after that.
So far both lights work the way they were designed.
Rob
10-12-2010, 06:41 AM
1989 25' Excella
1989 34.5' Airstream 345
Hobe Sound
My light works, but at times regesters low when not. I think the connection might be loose or the terminals need to be cleaned with a file. Mine work 98% of the time, so haven't fooled with them yet.
10-13-2010, 08:07 AM
The Hawk's Lair
1985 34.5' Airstream 345
BACK WOODS
My "Low Coolant" light flashes from time to time. I suspect it is the ground. Keep me advised please.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
11-02-2010, 05:19 AM
2012 31' Classic
Andalusia
, Alabama
Update...
I am still chasing bad grounds on these circuits. Stay tuned.
11-02-2010, 06:14 AM
2004 30' Classic Slideout
Between Here
, And There
low coolant light
This is just a stab in the dark based on my experience with the durmax engine. But if there is air in the system you will occasionally get the low coolant light. This usually happens when you flush the system and refill. There is actually a screw on the thermostat housing to bleed the air out. I know a lot of people say the system will burp and clear the air in a couple of hours after a drain or flush but others say they can not get the engine to burp and must bleed the air out. Just another possibility??
11-02-2010, 06:22 PM
2012 31' Classic
Andalusia
, Alabama
The probes are located in the overflow bottle. I think the circuit is just so sensitive, any resistance in the ground will throw it off.
11-03-2010, 06:32 PM
Silver Bullet
1986 34.5' Airstream 345
choctaw
, Oklahoma
I had the 'Water in Fuel' light would come on now and then. I pulled the wire off the light and it very lite again.
mel
11-03-2010, 06:50 PM
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens
, Georgia
I just bought mine in Indiana and driving back to Athens GA it came on while climbing the mountains in TN. I was only going 45 mph pulling my 08 wrangler up hill. Haha. I did add coolant to the full line. I got back no problems. I flushed the radiator all seems good. The rear differential was sludge, changed that too.
Athens GA
11-03-2010, 07:03 PM
1984 31' Airstream310
Ajo
I finally unplugged mine, AS is as infamous for grounding problems as Lucas in England was. I'd be interested in a fix, too, unless it means getting into the "rat's nest" of wires under the dash!
11-09-2010, 09:46 AM
Foothill Ranch
Can't wait to hear Rob!
Both of mine are on!
11-11-2010, 04:29 AM
2012 31' Classic
Andalusia
, Alabama
I hope to get back to work on this project this weekend or next week.
This week I have to take advantage of the great weather to finish a project for my dad & step mom.
Stay tuned!
11-11-2010, 09:30 AM
Foothill Ranch
Good job Rob!
Looking fwd to hearing your solution, and smooth sailing on the side project!
11-23-2010, 03:19 PM
2012 31' Classic
Andalusia
, Alabama
OK guys,
I have now officially given up on this project. The units I have installed just do not work. Like many other owners, I am just going to pull the bulbs out.
11-23-2010, 04:23 PM
Foothill Ranch
Whoa!
Good effort Rob, but take a breather, open a cold beverage of your choice, and collect your thoughts, and post what you tried to do.
I have no clue how a pair of connections on the tanks becomes a lit bulb on the dash.. and I have several... with black electrical tape over them.
I did however read a long post in the trailer repair section about the tank level units that Zepplinium built, and whilst 95% of it went over my head, there may be clues there!
http://www.airforums.com/forums/f443...tal-58532.html
11-28-2010, 05:30 PM
Silver Bullet
choctaw
, Oklahoma
unplug the light and get 2 more mile per gallon. Maybe I've have too may beers already:<)
mel
