Old 05-25-2009, 10:39 PM   #1
crashxx's Avatar
1983 30' Airstream 300
Weatherford , Oklahoma
Looking to find a MH but which one? Pros & cons?
Hello all, I've had the idea of finding a motor home for a few years & now I've decided to start serious looking. The airstreams have caught our eye and that's what I'm going after. With my limited knowledge on the subject, my pic is the 345. I think its the classiest. My questions for now are: Whats the diffrence between the airstreams & argosys?
Gas or desiel?
It will be my wife & I, a 6 yr old, & 9 yr old. How big?
Most traveling will be under 400 miles.
What are some of the more desireable things I should look for?
How well do these do in the stiff Oklahoma wind?
Do they ride solid? I rode in a buddy's, not airstream, and with every bump I thought it was going to shake apart.
Would a 310 be large enough for the four of us?
Thanks for all the guidance & help.
crashxx is offline   Reply With Quote
Old 05-26-2009, 01:24 PM   #2
Robfike's Avatar
1999 36' Land Yacht Widebody
Spencer , Indiana
The 345 is a great machine. There is enough room for your family to have a relaxed time. To me, anything smaller for 4 would be just too small. The owners of the 280's, 290's, 310's would probably think differently.
Almost all 345's are Chevy P-30 chassis with a gas 454 V-8. Mileage is about 7 mpg give or take.
Wind is much less of a factor as compaired to a "big box" type of MH. We have crossed the big bridge at Tampa durring high wind warnings with no big deal.
The ride is very dependent on tire pressure. Too much pressure, and you have a harsh ride. Too little, and the tires can overheat. The pressure recommeded by Airstream is really close. I use a pyrometer to check tire temp on the inside, middle, and outside of the tread area. This will show you the ideal pressure for each tire.
We have a 1986 345. Since they made more 345's than any other model, there are more available.
Watch for corrosion on the body arround trim strips, and windows. Make sure everything works, or reduce the price accordingly. The 454 V-8's go about 110,000 miles before overhaul if taken care of.
We LOVE ours, and would never think of having any other type of MH.
Rob
Robfike is offline   Reply With Quote
Old 05-26-2009, 01:36 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
That sounds like a great idea, could you elaborate?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-26-2009, 08:13 PM   #4
crashxx's Avatar
Thanks for the info. Any more is appreciated. What is the average price for a 345 in fair condition? I'm pretty handy and enjoy a good project.
Old 05-26-2009, 09:17 PM   #5
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
There are two 345's for sale on e-bay. Get on ebay and type in airstream in the search box. Something to check out.
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 05-26-2009, 09:40 PM   #6
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
I can't speak to the Argosy models, or the diesels, because I have no experience with either of those. But I will say that we love our 345. We had a 24 foot SOB before we got our Airstream. We enjoyed that moho tremendously, but the 345 is so much better. We think that we have at least another 20 years of camping left and we don't plan on ever getting rid of our current AS.
Keep in mind that if don't buy one that is already restored, the purchase price is probably just a down payment. We paid $18K for ours 4 or 5 years ago. We have since put nearly twice that into it. But that was the plan.
It didn't have breakdowns, we just wanted to upgrade.
Now we have a coach that cost a third of what several of our friends have spent, but at the campground, ours gets all of the attention.
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 05-26-2009, 10:01 PM   #7
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
As with any used MH...you will be making repairs.
Best with the Airstream is that all the repair and improvements will last much longer.
Your not investing in a SOB designed for a 7 year life span.
Under 400 nmiles?
I would get the 345 or 350.
The LE versions have a few extra features, as the boxed side curtains and a better counter top.
Keeping up with traffis is not a problem with these.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 05-27-2009, 10:43 AM   #8
crashxx's Avatar
I'd like to find one that needs some work. That way I can justify re doing it how I want it. I'm in the appliance/floor covering business so I have some resources available to me that will make it a little less painful. Do you guys know of any magazines that would be good to get ideas from?
Old 05-27-2009, 01:08 PM   #9
Robfike's Avatar
Spencer , Indiana
Tire pressure
I set my tire pressures on the 345 the same way I do on my road racing car. The amount of load on a tire must be balanced by it's pressure. This relationship can be checked using a pyrometer.
After running a few miles at highway speed, pull off in a safe place and check each tire the same way. You need to get your data quickly before the temps even out. On each tire, use the pyrometer to check and record the temperature at the outer edge, middle, and inner edge of the tread.
In theory, if the tire is at it's optimal pressure for the load, the three temperatures would be the same. In real life you will be looking for an even spread from one side to another. Like 145 outer, 147 middle, and 149 inner. This is due to camber.
If you see the middle temperature higher than the edges, the pressure is too high for the load. If the middle temperature is lower than the edges, the pressure is too low for the load.
I run my Tag tires about 10 psi lower than the duals as an example.
Using this method to determine pressure, you can arrive at the proper pressure for each tire.
Good luck, Rob
Old 05-27-2009, 01:15 PM   #10
Mike Leary's Avatar
Images: 11
Thanks, Rob, I'll file that great information and put it to use beause I have (not always) smelled tires after some runs, though the pressures have been checked.
Old 05-28-2009, 03:29 PM   #11
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Finding a Airstream that is in need of work ?
Whew...now thats going to be tough to find.
Click To See Me Wet
1972 Argosy 24'...
Old 05-28-2009, 05:32 PM   #12
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
We bought a 2005 Airstream Landyacht 30 footer w/ slide in August, 2007 and love it. It has the Chevy big block 454 (8.1 l) engine. The motor starts up beautifully and runs like a top. The body is fiberglass and has a beautiful finish to it. It's not aluminum and not as contoured as the 345, but still has awesome curb appeal and get's great comments when out on the road. The fit and finish inside is very much up to Airstream standards. Nonetheless, we have had to do some work to it. No matter what you buy or how much you spend on it, there will always be something you need or want to do to it.
Our unit has a queen bed, sofa and table with 2 chairs, so the 2 kids would have to share the sofa folded flat. Probably, you would do better with a dinette that drops down into a bed, along with a sofa and bed for sleeping.
Be sure to inquire about water leaks and inspect carefully for signs of water damage, (rust, water lines, rotted wood, mildew, etc.) Also, look carefully at the windows. Some are dual pane and oftentimes the seals break and fog collects between the panes. The only solution here is to replace the windows which is very expensive.
Good luck on your search and don't rule out the newer Land Yacht line.
Michigander is offline   Reply With Quote
Old 05-28-2009, 06:01 PM   #13
345bill's Avatar
Las Vegas , Nevada
We purchased our 345 around two years ago. Though the wife wants to work a few more years we use it frequently. Short trips, weekends, exc. and one 5000 mile round trip last summer. It's our first ever MH so I don't have experiance to compare with but I can honestly say the 345 has always provided every comfort of home, surprisingly easy to drive, it's on a chevy P-30 chassis w/454 gasoline and expect around 7 mpg. It's a "keeper" for us and sure glad we became part of the AS world.
I see the costs of buying one vary greatly just do your homework and you'll find anything you need to learn right here on these forums!
345bill is offline   Reply With Quote
Old 05-29-2009, 01:19 PM   #14
Auretrvr's Avatar
Iowa City , Iowa
We have a 310 and like its size...
We've had an '83 310 since late 2006. We looked for a unit small enough to fit into National Forest Service campgrounds and other places with limited pad sizes. Also, we can park it at home where anything bigger would not fit at all.
I think the extra length of the 345 is used mainly for a dinette and a wider kitchen counter but don't know for sure. Our seating across from the couch works fine as a dining place, so for us the extra dinette space isn't so important.
We spent $15,000 to purchase and another $25,000 on fixups. The most expensive fixup was stripping and recoating by P & S, a well regarded shop in Indiana.
Luckily, the engine and drive train were in very good shape and we were able to invest our efforts in new flooring, upholstery, curtains, captains' chairs, genset repairs, and a Gear Vendors overdrive/underdrive.
Also had to spend about $3000 on steering and tires.
Other nice features of the unit we bought were that it already had engine and transmission auxiliary oil coolers, a 'steer-safe' stabilizer, air bag leveling called Jet Air, and lots and lots of manuals and service records.
I'm not saying this to brag, but to indicate there are some really good values and some lemons out there for the shopper--and we were very fortunate.
We strongly believe in looking at serveral units before you buy, and in considering your impressions of the seller and how they used and treated the unit.
One caution: It's 25 years old. Any vehicle that old might bring an unpleasant surprise. We were SO lucky recently that our ignition module failed while the coach was in the driveway -- we had just got back from a 4 week 2000 mile trip from Iowa to the Great Smokey Mountains!!
We love our 'Ernestine' (named after the seller) and have really enjoyed RV-ing in this American classic, with ameneties of a much more expensive and newer type of unit!
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 05-30-2009, 08:59 AM   #15
crashxx's Avatar
Well, if any of you hear of any for sale around Oklahoma, let me know. I'm having a hard time finding any. One thing I'd really like is a queen bed in the back. If I understand correctly, I'll have to get a 325 or 345. Thanks for all the info. Its good to have a place to gain some quick experience!
Old 05-30-2009, 09:30 AM   #16
crashxx's Avatar
Are there size limitations in some parks? As I said, I'm completely new to this and just thought bigger was better.
Old 05-31-2009, 09:08 PM   #17
Auretrvr's Avatar
Iowa City , Iowa
Some parks, especially older ones...
We've generally looked for state park campgrounds and National Forest Service campgrounds for our camping--we like to be near the woods and go hiking. Besides the natural surroundings, we get the Golden Age Pass half price break. One of the campgrounds we were at last year was $5 a night!
While most RV campgrounds have room for 40 footers, the National Forest Service and some state campgrounds often have smaller pads--and sometimes only supply electricity at the site. Some have only non-electric sites.
AIR 15765
Old 05-31-2009, 09:56 PM   #18
TerraYacht's Avatar
Castro Valley , California
We've only had ours for about a year (same 30 ft s/o as padillab), but it would sleep your entire crew, at least right now: queen in back, double if you open the couch and the little dinette sleeper. Its not as enticing as the Argosy we met last week in Mariposa, but a newer low mileage has less investment required, except for the dual pane window issue. I was lucky enough to buy from the original owner and he upgraded with a Banks and some suspension stuff. Some of the sales issue was the good karma of the seller and his constant maintenance--I inherited his shop as well.
In my view you end up spending about the same amount between purchase price and the investment after purchase--its just a matter of how you split it.
The reliability is one reson we looked for a lower mileage newer moho: but it had to say "Airstream."
TerraYacht is offline   Reply With Quote
Old 05-31-2009, 10:29 PM   #19
crashxx's Avatar
Well, I bought a 83 300 today. It needs work but we're looking forward to it.
Old 05-31-2009, 11:47 PM   #20
Plantersville , Texas
great size
Congratulations on your new toy. I have a 83 300 turbo diesel. What are your configurations. I have rear bath, center twins, sleeper sofa and dinette in front . Plenty of room and comfortable. Good luck in getting her home. Mine has some hail dimples and a few dings on her sides, but she is still beautiful to me. They are just signs of age and useage.
Kay
carnegie1935 is offline   Reply With Quote
Convection Microwave Pros & Cons Foiled Again Stoves, Ovens & Microwaves 40 12-26-2010 11:29 AM
Pros & Cons of covering your AS searcher General Repair Forum 30 03-23-2009 10:35 PM
Pros & Cons of towing a jeep behind A/S Wayner 76 Tow Vehicles 5 06-01-2008 07:54 PM
Composting Toilets ( Sun-Mar or others) Pros & Cons? Rivka Waste Systems, Tanks & Totes 5 03-22-2007 09:33 AM
Fantastic or Stock Pros & Cons aviontt Roof Vents, Skylights & Fans 7 11-29-2003 09:01 PM
