Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
View Poll Results: Should the leveling jacks be down during winter storage?
Yes 14 25.00%
No 24 42.86%
Doesn't matter 15 26.79%
No opinion 3 5.36%
Voters: 56. You may not vote on this poll
Old 05-14-2008, 08:47 AM   #29
BudClem
TOG Unit Member
Profile:  1979 31' Excella 500
Marietta , Georgia
Thank you, very much for all the information. I will examine and provide feedback in a few days.
BudClem is offline   Reply With Quote
Old 05-14-2008, 10:28 AM   #30
ctdair
ctdair's Avatar
Profile:
HWH Schematics and Flow Diagrams
For the technically inclined and the curious this is a link to HWH and the hydraulic flow diagrams for various systems. Standard stuff really, but fascinating to those who work hydraulics. The sequenceing control of the kick down cylinder(not on all systems) operation before jack extension is interesting.Tried to find a cutaway or exploded veiw of jack online but its not there as they expect every one to just replace the ram instead of rebuild it I guess , and that really is the easiest fastest cheapest method. Will ask for them to email a cutaway if they have one.
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2002 Dodge Diesel 4x4 Dually
ctdair is offline   Reply With Quote
Old 05-15-2008, 08:10 AM   #31
ctdair
ctdair's Avatar
Profile:
Diagram of a HWH lifting ram. Looks quite well built. Voted for storing out in poll.
Old 05-16-2008, 05:53 PM   #32
ctdair
ctdair's Avatar
Profile:
Following is a communication from HWH technical service.
Hi,You where kind enough to forward a print of a jack
> cylinder. I have some questions that I hope you will be kind enough to
> help with.The ram is hollow so the nipple on the end of the ram would
> drain the fluid if bolt or plug removed? Second with the cylinder
> retracted there would be minimal oil between the cylinder and the ram
> since there appears to be a seal/wiper at the top of the ram?
Date: Fri 05/16/08 12:26 PM No the nipple at the bottom of the ram is machined on and can not be removed. The only way to drain any oil out of the cylinder is to either remove the switch or the fitting on top of the jack and turn it upside down to drain. Yes you are correct there is minimal oil on the cylinder when the jack is retracted. Thank you Joe Portelli
----- Original Message ----- From: <ctdair@netscape.com> To: <sales@hwhcorp.com> Sent: Friday, May 16, 2008 10:21 AM Subject: Dealer Diagnose Problem
I will suggest again leaving extended to protect the interior of the cylinder by keeping
it filled with oil since we cant access it to protect other wise , and coat the exposed rod
or cover it to protect it since we have access to it when extended , if you coat it clean the
coating off before retracting.
