Old 09-13-2013, 05:44 PM   #1
1964 24' Tradewind
Howell , Michigan
Leak
I have a bad water leak when it rains. It comes from bottom of the rear air conditioner. When I take off the cover I can't see the drain for the pan under the unit. Please Help. 85, 345 rear air
tommyt is offline   Reply With Quote
Old 09-14-2013, 06:40 AM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
More then likely you'll have to pull the unit and replace the bottom seal. Not as hard as it may seem but using two people would be a benefit. The only issue I see with the 345 is the curved roof makes it a little harder.
92landyacht is offline   Reply With Quote
Should check valve leak a little? KYAirstream Plumbing - Systems & Fixtures 7 11-04-2012 10:09 AM
Oh where, oh where is that leak coming from? idmtman Fresh Water Systems 0 11-28-2011 11:01 PM
Where Is My Leak? Chaplain Kent General Repair Forum 6 10-07-2011 11:55 AM
Frustration !!Water leak at front of trailer!! william Haym Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-06-2011 11:41 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
