Old 05-21-2016, 05:18 PM   #1
Whangarei , Northland
Land Yacht specs
Hi all - newbie here. I have joined in the hope someone will know the exterior width of a 1993 Airstream Land Yacht.
I can't find specifications or a brochure anywhere on the net.
This is of critical importance before I take the plunge and buy it.
Any help gratefully received.
Cheers
dords is offline   Reply With Quote
Old 05-21-2016, 05:20 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forum. A 1993 Land Yacht trailer should be 96" wide.
Old 05-21-2016, 06:35 PM   #3
Whoops - I should have qualified the title - it is a Class A motorhome - does that make any difference?
Old 05-21-2016, 06:47 PM   #4
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
Specs
What size is it?
We call ours "Ship Of Fools"
garypk is offline   Reply With Quote
Old 05-21-2016, 11:19 PM   #5
Hi Gary - it's a 33' Class A. Thanks
Old 05-22-2016, 05:33 AM   #6
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
I would have thought all your specs are on Airstream.com in the 90s Motorhome section. Look at the specs there.
Boom Sounds is offline   Reply With Quote
Old 05-22-2016, 06:49 AM   #7
garypk's Avatar
1998 31' Land Yacht
specs
Book specs 33.5' long 96" wide exterior. Read everything you can here especially about delamination of the exterior walls. Good luck in your search!
Old 05-22-2016, 09:30 AM   #8
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
That 96" width is body width. Anything hung on the outside, such as an awning or side mirrors, will add to the overall width. So if horizontal clearance is important, add at least 24" to account for the mirrors.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-22-2016, 10:30 AM   #9
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
After mirrors clear don't turn sharp or the 12 foot behind the rear axle will hit the wall
Old 05-22-2016, 05:14 PM   #10
Red face Land Yacht width
Thanks again Gary - where do I find those specs or do you have to have the manual on hand? Are they prone to delamination?
Re the mirrors etc - they are not counted in the width, (however, need to be folding), nor are handles etc.
Purely the coach body that matters.
First place I looked was on Airstream.com, but where are motor homes mentioned? I can only see Travel Trailers and Touring coaches. Can you give me a link to 90's motor homes section?
Cheers
Old 05-22-2016, 05:43 PM   #11
1993 Land Yacht M/Home
The other thing I need is the wheelbase measurement, if anyone knows it.
Overhang can't be more than 70% of wheelbase.
Someone mention 12' overhang on the Land Yacht - wow that seems a lot? Would we need a track bar fitted to counter such a long back end?
I have had to discount several brands because of the overhang being more than 70%, which is a bit hard to tell from photos.
Old 05-23-2016, 02:51 PM   #12
garypk's Avatar
1998 31' Land Yacht
Specs
If I can get this to scan...There! You asked about delam=almost all MoHos in the 90's into early 2000's used a "sandwich" of fiberglass over luan which will delaminate if it leaks & may even dry if it is stressed. So read up it is not always fatal & it can be repaired, but you have to be prepaired. As to the site look at Land Yacht & Legacy under Motorhomes.
Name:	Airstream MoHo Specs 001.jpg
Old 05-23-2016, 07:33 PM   #13
Going to re-label myself "dumb blonde"!
This is the site I'm going to... https://www.airstream.com/ and I can't see anything about motor homes - only Travel Trailers and Touring Coaches.
Am I on the wrong site?
BTW Gary - I did find that specs sheet earlier, but guess what's missing? The exterior width!
Old 05-24-2016, 12:04 PM   #14
garypk's Avatar
1998 31' Land Yacht
Oh I thought you meant on this site. On that go to service then out of the drop down "archive". scroll down through all the trailers & you will get to motorhomes. Classics, Land Yachts, Cutters & diesel pushers.
Cabinet specs - any specs out there KariRich Cabinets, Counter Tops & Furnishings 0 02-23-2016 11:58 AM
Specs 1990 Land Yacht mr_r Land Yacht/Legacy Motorhomes 4 09-05-2012 12:48 AM
2002 airstream land yacht xc365 s2002 airstream land yacht xc365 eBay Watch Airstreams on eBay 0 07-22-2011 09:10 AM
74 Airstream Overlander Land Yacht F131 Land Yacht eBay Watch Airstreams on eBay 0 04-02-2010 01:50 PM
70-80s Land Yacht specs?? Griswolds Buyer Guidelines 3 07-21-2006 03:43 PM
