Old 05-24-2016, 03:17 PM   #15
Whangarei , Northland
Thumbs up
Thank you so much Gary - I would never have thought of looking in "Service".
I have now found all the info I need, except the exterior width, which doesn't seem to be on any of the dimension lists.
Wheelbase ratio seems to be o.k.
However, if it's 7'6" interior, I'm presuming it wouldn't be more than 8' exterior.
We're allowed 98.5 inches max. and 70% of the wheelbase rear overhang.
There seem to be many Airstream enthusiasts out there - any particular reason for this? I know very little about the relative merits of USA RV's.
dords is offline   Reply With Quote
Old 05-25-2016, 01:03 PM   #16
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
Mine's 96". That was the standard for years until Federal Hwys changed to 102". 7'6" inside + 3"walls.
The following comes from the iconic aluminum sided trailers & later motorhomes. The perception is that they are well equipped, expensive when new & well built.
We call ours "Ship Of Fools"
garypk is offline   Reply With Quote
Old 05-25-2016, 10:55 PM   #17
Hi again - I really want an Airstream, but am finding it hard to locate one.
I have however, found one or two - one is a 1990, reasonably low miles and clean except for the back corner of the bedroom where it's obvious there's been a leak. (Wallpaper all wrinkled). There is no delamination at all.
(Advert said "no present or past leaks")! I'm not sure whether to buy it or not - can I trust this dealer to be telling it as it is?
Question is...are they aluminium or steel framed, or timber? I tried to find this info, but so far haven't been successful. Would make a difference to what damage has been suffered, if any.
I would appreciate your thoughts
Old 05-26-2016, 07:56 PM   #18
garypk's Avatar
1998 31' Land Yacht
They are steel. If you go to land yacht (u r now in general more ho) & search delamination u will see what can happen .mine had some leaking u will find damage by pushing on inner & outer walls where are you what's the price & no don't trust anyone. Find out for yourself now or u will find out later.
Cabinet specs - any specs out there KariRich Cabinets, Counter Tops & Furnishings 0 02-23-2016 11:58 AM
Specs 1990 Land Yacht mr_r Land Yacht/Legacy Motorhomes 4 09-05-2012 12:48 AM
2002 airstream land yacht xc365 s2002 airstream land yacht xc365 eBay Watch Airstreams on eBay 0 07-22-2011 09:10 AM
74 Airstream Overlander Land Yacht F131 Land Yacht eBay Watch Airstreams on eBay 0 04-02-2010 01:50 PM
70-80s Land Yacht specs?? Griswolds Buyer Guidelines 3 07-21-2006 03:43 PM
