There is no compressor or air tank on our MH. It had been removed before we bought the RV. It should be in the space just forward of the left front wheel. The mounting, wiring and air hoses are still there.
Does anyone know what type of equipment was there originally, and/or what I can replace the missing parts with?
So... I did some more research. The horns on the roof are from Grover Products Grover Contact Info . I do have an air tank and a presure regulator on the shelf in the wheel well. (I wonder if the wheel well was the best location for this equipment.) I d know yet, who made the tank but the presure regulator is from "Furnas". I am attaching a picture. Does anyone else have a setup like this.
1965 17' Caravel
1961 24' Tradewind
Ephrata
I do not know about AS MH but, I did install a grover kit with compressor on my streetrod and it has worked flawlessly for over 30,000 miles mounted to thew frame under the car with no protection.
Low end compressors are all over the place. I used a Valair to replace my suspension compressor and it's been great. They draw a lot of amps but with proper gauge wire it's not a problem. Check eBay and you'll find lots of options.
Glen Coombe AIR #8416
1984 28' Funeral Coach
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
