I will check compartment lights but I believe they are all, on switch in console. I did not notice independant light switches in compartments. I already checked that but I will double check.
Smily
__________________ Ken Smillie
My 1994 36' Classic MH is for sale See it in the classifieds
The step is energized even if it is out, or in. It is just waiting for a signal to open or close. There should be a small on/off switch to power the step down. When I had one I used this switch to keep the step in while the rig was stored, and out when camping. That way it was not going in and out all the time. This is especially helpful if you are used to flinging the door open and stepping right out. The step has a delay and sometimes I would start to step out and the step was not there yet
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
The Hot Water Heater and the Refridgerator both consume energy from the battery when in the "on" mode while in storage, as do some types of Furnace Thermostats. For winter storage, don't forget the possibility that the furnace is operating when the inside temp of the MH approaches 40 degrees (usually the minimum temp setting of a thermostat) unless the thermostat has an "off" switch.
Any dirt or corrossion presenting a path to ground will contribute to the additive battery drain. Most MH's have a battery cut-off switch close to the battery compartment. This switch is the first line of defense for preventing the batteries from draining while in storage.
Dennis
I have been to furnace school, but correct me if I am wrong. The furnace is on coach batteries and not the engine battery. As is the reefer and other appliances.
I am not certain but I thought that the step switch was in the off position but I could be mistaken.
I cant help but think it is something other than step. When I first purchased unit, I did not know about step switch and I was going in and out of unit frequently. The step was cycling in and out everytime I boarded coach. The battery lasted for days, actually it never went dead. I started having battery problems when I got home. I immediately changed battery to new one. Reason being, I applied battery charger and the indication was that the battery would not take a charge due to bad cell (s).
Stumped, but I do have owners manual by my side here at office. I will look for wiring diagram.
Smily
As long as the step is off pull the battery cable and connect a test light between it and the battery and see if there is any other draw. If it doesn't glow you know it was the step.
