Old 02-11-2016, 10:52 AM   #1
ScottP's Avatar
2020 27' Globetrotter
2019 Interstate Lounge Ext
Jackson Hole - Tetons , Wyoming
Jackson Center Upgrades?
We're planning a July trip to attend a wedding near JC.
If you were so close to the factory, would there be any upgrades you'd consider doing?
This unit is a 2016 Interstate Extended
Scott
ScottP is offline   Reply With Quote
Old 02-13-2016, 09:20 AM   #2
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
What Interstate options don't you already have? Most come well equipped. The VB Air Suspension would be a good upgrade if you don't have it already, but I'm not sure Airstream will do air suspension upgrades.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Boxster1971 is offline   Reply With Quote
Old 02-19-2016, 05:18 PM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Trading it for a Classic motorhome........
Isuzusweet is offline   Reply With Quote
Old 02-19-2016, 11:32 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Problem is, except for the air suspension, everything on an Interstate comes as standard equipment.
If you have the auxiliary battery under the hood, you might talk to the Jackson Center folks about removing the relay between the starting battery and auxiliary battery so that they're permanently connected in parallel, doubling your cold-cranking amps. With the relay in place, the battery under the hood is dead weight because nothing is powered by it and it's not connected to the starting battery until AFTER the engine is running. Who knows, if you can convince them, that might become a standard procedure on future models.
Old 02-26-2016, 09:11 PM   #5
ScottP's Avatar
Thank you Protagonist and others for your feedback.
Maybe I'll just concentrate on requesting a Jackson Center tour.
Best,
Scott
Scott
Old 03-01-2016, 07:36 PM   #6
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Definitely do the tour. I go through it every 4 or 5 years. Learn something every time.
Gregsch is offline   Reply With Quote
1950s Center of Jackson Center PeeWee Airstream History 4 08-03-2009 08:42 PM
Small fire at Service Center at Jackson Center hohne Our Community 32 06-07-2004 10:00 PM
A question about the “Winter Program” at Jackson Center, Ohio nds Commercial Listings 1 11-30-2003 12:40 PM
Ever toured the Jackson Center plant? KY Girl Our Community 21 11-17-2002 10:04 PM
