Old 10-08-2007, 12:43 AM   #57
1960 24' Tradewind
santa barbara , California
I for one cannot believe the sauga that has gone on for a month . I mentioned somewhere in a post or PM about rebuilt master cylinders a
BIG NO .your buying a cylinder that has been cleaned and maybe honed inside
with new piston an rubber cups .The problem is that master cylinders and wheel cylinders corrode inside ,leaving pitting and damage .you cannot hone this out ,and further the surface of the bore in the cylinder is now rough
from the honing process ,yes it may feel smooth ,but little scratches now are in the steel (honing marks) and fluid can escape around the rubber cup seal .
A new master cylinder has a smooth almost polished machine surface .
This shop using a rebuilt master cylinder ( and multiple times I might add )
does not have a clue as to how to properly perform the work .The hydroboost
units can be defective ,but that has nothing to do with low pedal or spongy
pedal in any way .You bleed the brakes with the engine off ,NO hydro boost
is in play here .I perform automotive and truck repairs including RVs and those
P-30 front hoses and calipars that give alot of problems ,old hoses especially
do to rotting rubber to the inside causing the hose to restrict fluid movement
I use NEW quality master cylinders and wheel cylinders without exception in
my repair shop .Id never install a rebuilt master cylinder no matter what .
you have to go with quality parts everytime ,so the job will go right the first
time . Things can and do go wrong even then ,but using the best parts helps
ensure the jobs done right .I read many posts that encourage using the cheapest price part available with no thought to quality ,the cheapest price
does not mean the best quality .Those rebuilt master cylinders cost about
29 bucks more or maybe less at Autozone ,A quality new unit is higher priced
and far far better . A new master cylinder could have solved this fiasco alot
sooner ,had the shop not gone el cheapo on the part .bottom line with this
repair facility ,if they don't know how to install a master cylinder and bleed the brakes (bench bleed master cylinder first) install ,bleed all wheels ,
somthings really wrong there .If I allowed somthing of this type to go on for more than a few days or a week I wouldn't have any customers .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 10-08-2007, 05:10 AM   #58
Scott, I couldn't agree with you more. I'm extremely glad both the hydroboost and the master cylinder ended up being new components and not rebuilt ones.
I think I mentioned earlier that the repair shop doesn't cater to RVers, instead their main business is fleet work. Seems to me if they don't want to treat customers equally they should at least inform them where they fall on the priority list before they actually start the work.
Thanks for the tips and info.
Am I being reasonable? truebebeblue Trailer Values 12 11-11-2006 03:43 PM
Reasonable Retail Price Range for 25-28' Excellas Streamer1 Trailer Values 2 08-30-2006 03:53 PM
IS this a Reasonable Price for a Diesel Powered '94 Land Yacht(34')? Mikeinmiami General Motorhome Topics 12 03-29-2006 07:51 AM
Permant floor at a reasonable price? malconium Repairing/Replacing Floor &/or Frame 40 02-01-2006 01:18 PM
Price for floor replacement and frame repair 68Glbtrotter Repairing/Replacing Floor &/or Frame 35 12-06-2005 11:28 PM
