Old 08-24-2010, 06:31 PM   #1
LAFAYETTE , Colorado
Interstate 3500 pro and con
We want to travel for a year in an Interstate 3500. Yet to purchase.
What are the pros and cons? Ty and Janet Colorado
TY PECK is offline   Reply With Quote
Old 08-24-2010, 07:58 PM   #2
ben322's Avatar
2009 Interstate
Bethesda , Maryland
Well, being on the road for a year, I would say one of the biggest negatives is the lack of storage space. Consider removing the seat behind the driver and install a custom cabinet. That's really the main disadvantage and you will typically not be lounging around inside. We travel as 2-adults & 2-teens and do a lot of hiking so we're not spending a lot of daylight hours inside unless we're on the road.
That said, I consider Sprinter Class MH a huge advantage when when driving on roads like Glacier NP Going To The Sun Road, southern entrance to Sequoia NP, the eastern entrance to Zion NP, St. Augustine drive-on beach, etc. We've been on lots of roads where a larger unit would either not be allowed or would be doing 3-point turns at every switchback. Then there's the NP/SP campgrounds. Being a Class B, we're typically allowed in tent-only spots that allow cars. Many of those campgrounds have limited RV spots and once you're over 24/26 feet your choices become limited which is why many larger rigs tow a car to sightsee from the commercial CG outside the Parks. We also don't usually stay in one spot more than 3-days so mobility is a higher priority. The on road manners of the 3500 chassis is superior to any SRW variant.
I looked at all the Sprinter based Class B RV's, (and used to own a Roadtrek), and found the AS to be the best fit & finish.
Ben
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Researching Interstate 3500 TY PECK Member Introductions 0 08-24-2010 04:58 PM
air con drawing 30 amps... werpknarly Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-20-2010 11:20 AM
Wired Magazine reviews Interstate 3500 koltys Airstream "In the News" 2 12-13-2008 06:25 AM
2008 - 2009 Airstream Interstate 3500 22'10" Colonial Airstream Commercial Listings 7 06-05-2008 09:47 AM
Air con Installation Dannear Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-23-2006 03:04 PM
