Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 04-18-2005, 11:15 AM   #1
1985 34.5' Airstream 345
Marietta , Georgia
Send a message via MSN to 85/345
Installing screen door
I am trying to install a new (used but new to me) screen door. The screen door is from a 78 Argosy and according to all my measurements should work (let me know if I'm wrong). The AS didn't come with a screen door, it was removed by one of the PO. One of the hinges for the screen door is in good shape the other one is broken and needs to be replaced. The question is how do I get the pin out of the hinge for the door so I can remove the hinge for the screen door? Once I remove this pin can it be reused or do I need a new one?
Brian
85/345 is offline   Reply With Quote
Old 04-18-2005, 12:57 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
Brian,
The hinges I have seen form Airstream come with all three pieces already attached. Inner and outer hinge for the door and the intermediate hinge for the screen.
I do not know if driving out the pin and replacing it is the best route to go as the aluminum will likely expand when you do this and the pin may not be able to be driven back in to a fully seated position. Making the door loose on the hinges
The hinges themselves are a standard item from what I have seen, but I do not have an exact cost. There is a difference between the upper and lower ones. I also know the hinges are the same ones whether you are talking classic MH or trailer. They are just reversed. on a MH the one that is marked L goes on top.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-20-2005, 09:17 AM   #3
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
My service manual has directions for removing the screen door and it says to drill out the rivets, not the pins.
Chaplain Kent
Forest River Forester 2501TS
Chaplain Kent is offline   Reply With Quote
Wooden screen door eraffety Airstream Motorhome Forums 7 06-20-2011 07:46 PM
Door Catches niftypkg Doors & Locks 4 05-22-2007 05:09 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
screen door slide Alice Cabinets, Counter Tops & Furnishings 3 07-10-2002 07:56 AM
Screen door for 310 MH kzener40 Airstream Motorhome Forums 1 06-14-2002 10:21 AM
