Old 06-20-2016, 11:32 AM   #1
KB6YAF's Avatar
Olympia , Washington
Installation/Removal of an '83 Airstream window screen
I have a 1983 Airstream 310 motorhome and need to install a window screen on the window nearest the entry door. When I bought this rig, the screen was missing and I managed to find one. Now, just how does one install it? it's curved of course, but I have no idea how it installs without bending it....So.....Help please!!
Russell Decker,
Olympia, WA
KB6YAF is offline   Reply With Quote
Old 06-20-2016, 03:44 PM   #2
1977 20' Argosy 20
Arlington , Texas
By all means don't bend the frame. I think that your windows are like the earlier Argosy motorhomes. The screen as well as the sliding glass windows are held in place by the fuzzy schegle in the window frame track. Usually there is a portion of the fuzzy that can be removed. Then the screen (or window) can slide over to the area where the fuzzy is removed. With the screen in the removed fuzzy area it can fit up (or down) into the channel just enough for the opposite side to slip over the channel lip and out (or in for re-installation). Often the fuzzy goes bad over time and fresh new fuzzy is available from Andy's Inland RV in California among other places.
The screens and sliding windows can be "re-sealed" in this manner. Especially with the glass do not force them in or out of the channel. Just exert a lot of patience to get the screens or windows aligned just right to come out or go into the channels.
Good luck
Gregg
GWallace is offline   Reply With Quote
Old 06-21-2016, 06:37 PM   #3
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Russell Decker,
Olympia, WA
If you are talking about the flyscreens with the aluminum frame, you will find 2 plastic tracks, one on the bottom and one on the top. They are held in place by very small screws. Carefully slide the tracks out after removing the screws. Once they are out, you can remove or install window screens.
Once the screen is in place, you need to carefully slide the plastic strip back in the channels.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
window screen removal beachplace Windows & Screens 1 03-18-2015 03:17 PM
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
2001 Safari Window Screen removal TincanRitz Windows & Screens 2 10-11-2013 04:23 AM
Sliding Window Screen Removal jking Classic Motorhomes 2 11-07-2010 02:23 PM
'solar screen' replacement window screen NJtoNC Windows & Screens 3 06-23-2010 03:56 PM
