Old 11-16-2012, 04:47 PM   #1
Imagine my surprise...
...as I was drilling a hole for a ground screw in one of the 1"x2" cross frame members on our 310 when just as the drill bit broke through water started flowing out
You can see the hole in the middle of the wet spot in the picture. If I had to guess I would say more than a cup of water poured out before it stopped.
In general I can't think of any easy way for water to get into the tube. This is one of the square tubes that are riveted to the truck chassis. The body shell and floor is then set on top of this framework and screwed into place. When I get time tomorrow I'm going to see if I can get a better idea of where the water might have gotten into the tube. I'm hoping it is an isolated problem and not indicative of a much larger one.
Needless to say this surprise did NOT make me happy
Old 11-16-2012, 08:13 PM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Not good! I'd drain as much of the remaining water that must be below the drill hole too. There must be a roof leak somewere above that frame member. Good luck finding it.
92landyacht is offline   Reply With Quote
Old 11-17-2012, 06:21 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I once drilled through the bottom of a holding tank the trailer owner had installed under the bed. That was a surprise I don't want again...
Old 11-17-2012, 06:28 AM   #4
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Is the skin riveted to that tube on the outside? I bet one or more rivets are leaking though. Or some prior owner used a pop rivet.
Bigventure is offline   Reply With Quote
Old 11-17-2012, 06:36 AM   #5
1994 30' Excella
Mississauga , Ontario
Since it is a steel tube, I assume it is the frame under the floor. Nowadays all automotive frames have large openings to allow water that "will, not may" get in find a way out again. I would create drain holes.
Al
Al and Jean
TAC ON-3
Old 11-19-2012, 05:47 AM   #6
Hopefully it was a small drill bit
Old 11-19-2012, 06:00 AM   #7
This picture is from a 345. The same tube framework is on our 310. The tube I drilled into is the vertical one in the center. The only place I see for water to enter would be through one of the screw holes, which are on the inside of the motorhome. I'll keep looking to see if I can find an obvious access point.
Old 11-21-2012, 06:06 PM   #8
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Condensation inside the tube perhaps?
Robfike is offline   Reply With Quote
Old 11-21-2012, 06:10 PM   #9
Rob,
I think there was WAY to much water for condensation. Anything is possible I suppose but it sure was a lot of water. Also when I dismantled the 345 and cut those same tubes no water came out.
By the way figure on me being there sometime in the evening of Wednesday December 5th.
Old 11-21-2012, 06:45 PM   #10
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Factory filled frame tubes
Oh no - that water was factory installed! If the tube was factory filled, then you better refill it. It's probably like the smoke filled wires in British cars. As soon as you see smoke escaping from the wires, you know that they will no longer be able to carry current, and the car stops running.
robert claus is offline   Reply With Quote
Old 11-21-2012, 07:26 PM   #11
You know, after seeing all the other odd and crazy things I came across while dismantling a 345 I wouldn't be surprised to find that water was deliberately placed there by the factory
Old 11-21-2012, 07:39 PM   #12
Well Preserved
1993 21' Sovereign
It was an inch and a quarter hole saw...
Old 11-21-2012, 07:48 PM   #13
Well, that should teach you to always drill a small pilot hole first
Old 11-21-2012, 08:39 PM   #14
Well Preserved
1993 21' Sovereign
Y'all might have learned a few new words if you had been around that day...
