Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 12-12-2018, 02:26 PM   #1
2006 39' A-Series
St. Augustine , Florida
Hydraulic leveling jacks
My leveling jacks on my A39 Motorhome will not retract. It is made by
LCI Leveling Systems. Called support tech at factory for different solutions.
Replaced solenoid and control panel by drivers seat. Nothing has worked.
Anyone else had this problem? Got any ideas?
airdan is offline   Reply With Quote
Old 01-01-2019, 12:53 PM   #2
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepherdstown , West Virginia
Images: 14
Never had that problem but my 2 front levels were leaking fluid. Turned out the seals were bad and they were fixed for $100 at a tractor dealer in Montana. In your case its either an electric control issue or solenoid malfunction that's not allowing the fluid to retrack from the jacks.
Mike1997 is offline   Reply With Quote
Old 01-05-2019, 09:44 AM   #3
PSchw's Avatar
2005 39' Skydeck 390 SD
Hillsboro , Texas
They retract by spring pressure. On mine the front the spring is on the outside and on the rear n the inside. If there is to much dirt build up on the shaft it will get stuck and the spring is not strong enough to retract it.
I had it once and pushed the leg back with a wooden board. Now I frequently clean and lube with silicon spray. Never had the problem again.
PSchw is offline   Reply With Quote
Hydraulic leveling jacks bobnmary Repairing/Replacing Floor &/or Frame 16 12-12-2018 01:57 PM
Hydraulic Leveling Jacks Wilbur McLamb Jacks, Stabilizers, Lifting and Leveling 19 02-01-2017 08:25 AM
Hydraulic leveling jacks crazeevw Mechanics Corner - Engines, Transmission & More... 7 03-22-2012 07:34 AM
Can I add hydraulic fluid to jacks? lululand Jacks, Stabilizers, Lifting and Leveling 5 06-08-2011 02:47 PM
hydraulic jacks str8strm Classic Motorhomes 5 10-25-2006 07:19 PM
