Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 07-17-2008, 02:23 PM   #1
kdenault
Profile:  1965 26' Overlander
Holland , PA
How much can a 20' MH tow?
Looking at a small MH to tow a gutted 1965 Overlander (no appliances, no holding tanks, no beds, no water pump, no water heater). Looking at a 20' MH with a 350 engine. Could this tow the Overlander? Or should I look for a 20' MH with a 454 engine?
Kathy
kdenault is offline   Reply With Quote
Old 07-17-2008, 07:44 PM   #2
kdenault
Holland , PA
Hoping to get some input. Sending it back up again.
Old 07-17-2008, 08:57 PM   #3
blacksheep
blacksheep's Avatar
Vincennes , Indiana
Hi Kathy,
In 1983 my church bought an old Overlander ('60's?) and refurbished it to give to missionaries in Nogales, AZ. My uncle volunteered his mh to tow the AS from Indiana to AZ and I got a free trip for helping with driving. The mh was a 1972 Winnebago 24' with a Dodge 413 engine, did a great job pulling the Overlander. If you are looking for a newer mh ('90's or newer) I suspect a 350 with the right rear end ratio would work since it would have fuel injection and computer management.
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 674,000 miles,a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 250,000 miles!
blacksheep is offline   Reply With Quote
Old 07-17-2008, 10:10 PM   #4
bkahler
Profile:  Jefferson , Arkansas
Kathy,
We are going to use our 20' Argosy motorhome to tow our 31' Excella 500 that is being converted to a two car hauler. The trailer isn't done yet (estimated weight loaded will be 6,000 lbs) and the motor is being rebuilt in the Argosy. We will be using a 454. The Argosy came to us with a fresh 350 but we opted to replace it with a 454. We felt the extra torque would be required to haul the trailer.
No matter what you would want to reinforce the hitch on the Argosy motorhome to allow for the heavier tongue load and trailer load.
Keep us posted as to what you end up doing.
"Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
Old 07-18-2008, 04:01 AM   #5
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
My 20' Argosy has a 454 with 411 gears, would certainly tow the trailer. I would look into beefing up the rear suspension.
Shamless Plug, the Peanut is looking for a new home
'74 Overlander (Rear Bed)
'77 20' Argosy MH (Looking for a new home)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w)
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 07-18-2008, 10:10 AM   #6
bkahler
Kathy,
Your search is over . Balrgn's would be just the ticket for what you're looking for. Take a look at his web page where he shows the work that he's done on the Argosy. I don't see how you could go wrong with Peanut.
Old 07-18-2008, 10:13 AM   #7
kdenault
Holland , PA
more info??
Balrgn,
Checked out your website--amazing work on the MH. I've emailed you for more info, price, etc. I'm going to look at another MH today--but I'd like to find out more info about yours. Hope to hear from you soon.
Kathy
Old 07-18-2008, 10:21 AM   #8
bkahler
Kathy,
Being an owner of a 20' Argosy and a 1984 310 Classic motorhome there are some things you want to look closely at. The front suspension is an area that almost always needs some kind of work. Our 310 even though it only had 90,000 miles on it had horrific steering. It was so bad that it was spooky to drive on the interstate in windy conditions. We've spend several thousand dollars on the suspension so far and we're not done yet and that's with me doing most of the work. Tires are another thing you need to look at. Anything older than 4 or 5 years and you're going to want to replace them.
Balrgn has done an awful lot of work to Peanut that you will likely have to do to any other motorhome you buy. I don't know Balrgn personally but from what I've seen from the pictures on his website he knows what he's doing and has done a good jub.
Just food for thought!
Good luck in your search!
Old 07-18-2008, 10:52 AM   #9
balrgn
balrgn's Avatar
Images: 74
Originally Posted by kdenault View Post
Balrgn,
Kathy
Info sent. E-mail me at home I can send movie clips
www.balrgn.com
Old 07-18-2008, 03:56 PM   #10
bkahler
Balrgn,
Would you happen to have the part #'s for the front springs you used on Peanut? I need to replace them on ours as well and it would be nice to get it right the first time
By the way thanks for posting the info and pics of the work you did on Peanut. It always helps to have photos as reference points.
Old 07-18-2008, 05:24 PM   #11
balrgn
balrgn's Avatar
Images: 74
Originally Posted by bkahler View Post
Balrgn,
They are Standard Springs fro a P30 Chassis, I'll see if I can dig up the order. I got them local, there is a place in Manchester NH that stocks them.
www.balrgn.com
Old 07-18-2008, 07:12 PM   #12
bkahler
Balgrn, any help would be appreciated.
Old 07-19-2008, 04:10 AM   #13
balrgn
balrgn's Avatar
Images: 74
Balrgn,
Kathy
How did the inspection go? Were you able to get pics? We like pics..!
www.balrgn.com
Old 07-19-2008, 05:46 AM   #14
balrgn
balrgn's Avatar
Images: 74
Thumbs up Weights
I found my original owners manual!
Maximum loaded trailer weight which yo can pull with this vehicle is 4000 pounds.
I knew I saw it in there
Here are a few interesting things
GVWR = 11,000
Curb Weight = 7,835
Allowable Additional Weight = 3165
Allowable Weight per Axle (rear) = 2550
Allowable additional weight addresses All Options including LPG, Waste Water Food supplies etc.
Curb Weight includes ALL engine Fluids - full tank of Gas - Oil - Coolant
www.balrgn.com
Got our new 20' Safari SE Wayne&Sam 2007 Safari 9 07-20-2008 11:34 AM
20' MH? Value, floorplan, etc Stefrobrts Trailer Values 3 11-05-2007 04:04 PM
Just Purchased 20' Minuet Dan S All Argosy Trailers 12 03-30-2007 11:43 PM
73 20' Argosy Vancanargo20 Member Introductions 2 03-15-2007 07:39 PM
74 Argosy 20' for $? 3x2x4sp389 Trailer Values 6 03-09-2006 01:05 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
