Old 09-16-2012, 09:09 AM   #1
How many motorhomes have this fitting installed?
While removing the electrical and water reels from the 345 this morning I noticed this female hose fitting attached to the side wall of the compartment. Tracing the hose I found that it is attached to about a 2" round flange on the deep end side of the black water tank.
My only guess is that it is a flush line of some sort. I'm also guessing that the round flange on the side of the black water tank is actually some sort of check valve or at least I hope that's what it is, otherwise you'd have a nice flow of something back into the compartment
So the question is, is this an Airstream installed product or is it an aftermarket item added by some previous owner?
Old 09-16-2012, 10:04 AM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
We do not have one of those.
Waipio Rim is offline   Reply With Quote
Old 09-16-2012, 10:17 AM   #3
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
I don't have that either. I do have two female connections on the side of the motorhome above the valve pulls for the black and grey tanks. I use them each time I dump tanks as they are connected to tank flush system. As a result we don't have the need to use any tank deoderant as they have never emitted any odor.
raveson is offline   Reply With Quote
Old 09-16-2012, 12:20 PM   #4
345bill's Avatar
Las Vegas , Nevada
nothing like that on our 1990 either.
345bill is offline   Reply With Quote
Old 09-16-2012, 01:32 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The "newer" trailers have this fitting. It could have been retrofitted to the motor home in the 1990's or so.
Old 09-17-2012, 06:36 AM   #6
Sounds like a handy addition to have. I might have to remove it from the 345 black water tank and install it on either the Argosy or 310.
Thanks!
Old 10-27-2012, 08:35 AM   #7
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
That is probably a hose connection for a "Tornado" black tank spray unit installed by a PO. We installed one in our '86 345, but I installed the hose connection in the support for the gray tank dump valve handle.
Works pretty good. The head in the black tank spins and sprays water all over in the tank.
Rob
Robfike is offline   Reply With Quote
Old 10-29-2012, 08:00 PM   #8
Rob
Rob,
This must be what you're talking about. I'll have to look at the 345 black water tank to see if it looks the same.
Tornado Rotary Rinser
Price isn't bad and if it works as good as you claim it would be a nice addition to the system.
Thanks!
