Old 11-22-2015, 08:43 PM   #1
Silvr_Lining's Avatar
2007 16' Bambi
San Rafael , California
How long with no fresh air?
Hello fellow airstreamers,
I worry about fresh air in our 16' Bambi. With everything closed up and an external electric heater going (shore power) should I have worries? And what about when we use the propane heater?
Silvr_Lining is offline   Reply With Quote
Old 11-22-2015, 09:03 PM   #2
Goal15's Avatar
Dallas , Texas
We always crack a window when sleeping with the furnace on, and quite often do so the rest of the year just for fresh air's sake.
I'm kind of picky about fresh air. I even do it at home if we are using the fireplace.
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 11-22-2015, 09:07 PM   #3
stsammy's Avatar
2015 22' FB Sport
Toronto , Ontario
Same. We always crack a window. We have two adults & a five year old in our 22, so I find we need the fresh air, or we wake up with condensation on the windows
stsammy is offline   Reply With Quote
Old 11-22-2015, 09:09 PM   #4
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I don't know if you're asking about storage or in use but opening the bathroom vent (without the fan) will help and if you have cover over your fantastic fan, crack that an inch or so. Should be all you need!
Old 11-22-2015, 09:54 PM   #5
Mission , Texas
I found this interesting ...
http://members.shaw.ca/tfrisen/how_m...r_a_person.htm
nrgtrakr is offline   Reply With Quote
Old 11-22-2015, 10:02 PM   #6
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
If you are lucky enough to have an air-tight Airstream, you should open a window!
Otherwise, just plug the holes with a screen to keep the rodents out?
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 11-22-2015, 10:32 PM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
HVAC designers use 1 or 2 air changes per hour for residential spaces in general, but 15 air changes per hour for kitchens and bathrooms to deal with odors and water vapor in the air, and 12 air changes for dining areas to deal with odors. This mostly has to do with the size of ducts and AC registers in different rooms, but the same principle can be applied to a trailer as well.
Rather than calculate different rates of air changes for different parts of your trailer, an average of 4 air changes per hour should be considered the minimum for air quality purposes.
One air change is letting in a quantity of fresh air equal to the total volume of the trailer in cubic feet, and exhausting stale air in the same amount. Given the approximate width and height of an Airstream's body, that's approximately a number of cubic feet per minute (not per hour) equal to the length of your trailer. So if you have a 25-foot trailer, to get 4 air changes per hour you want 100 cubic feet per minute of air flow. For a 30-foot trailer, you'd need 120 cfm.
For proper air changes you've got to have both an inlet and an outlet. A 4-inch bathroom vent fan will extract about 100 cfm, as long as you've got a window open to let in the same amount of air. A Fantastic Fan or MaxxFan 14-inch roof vent will move about 180 cfm on its lowest speed setting.
So for Silvr_Lining in a 16' Bambi, cracking open one window and running your bathroom vent should be enough to ensure that the air doesn't get stale. For someone in a 34' Sovereign, leaving a Fantastic Fan running on low and one or two windows cracked open should do the trick.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-22-2015, 10:35 PM   #8
cameront120's Avatar
1972 25' Tradewind
These trailers are far from air tight, so a lack of oxygen shouldn't be a concern (barring any faulty propane fired appliances). You will want to crack windows or a roof vent to reduce interior condensation.
North Vancouver, BC
Old 11-23-2015, 04:34 AM   #9
mandolindave's Avatar
It's not even about people liking fresh air.
It's about not getting dead.
The safest heater as far as asphyxiation is electric, obviously.
I don't know how safe it is to sleep in a closed up camper with no heater.
I don't know how safe the propane furnaces are but they at least have a fresh air supply. Are CO2 warning systems just in case there is a malfunction??
The stand alone catalytic propane heaters are dangerous if used in a confined area. you NEED to crack a window. I read that 8 people a year die due to these heaters
mandolindave is offline   Reply With Quote
Old 11-23-2015, 05:04 AM   #10
Gainesville , Florida
I use a co detector, not co2, ans still crack a window for condensation relief and peace of mind. If you are worried about your furnace please have it checked by a professional. Others are correct, an electric heater is great if you have hookups or a generator, we use one of the oil filled ones with a small fan behind it on low to circulate the heat. Good luck, have fun.
Old 11-23-2015, 06:41 AM   #11
Mission , Texas
The propane heat brings in outside air to burn, then exhausts that outside. A CO monitor will do just that, detect carbon monoxide (a product of burning propane gas) which could come from the range/oven, a catalytic heater, or (if damaged) the furnace.
Old 11-23-2015, 09:23 AM   #12
2007 16' Bambi
Thanks all,
It just can get darn cold but I do like to keep a window open a little.
I didn't think about condensation... A VERY good reason to keep air flow going!
-Marc
Old 11-23-2015, 09:50 AM   #13
Perhaps you are forgetting that the stove burns propane inside where it can make carbon monoxide in the trailer. And it's why one shouldn't use the stove for a heat source.
WBCCI #1105
TAC LA-4
Old 11-23-2015, 10:03 AM   #14
Limon , Colorado
I agree with everyone the best thing to do just crack a window. First off, you are getting fresh air and come on what gets better than that. Second I know your asking about it being a safety issue. I would still have window crack. Not 100% sure having all that is to safe.
Jim_Mullen is offline   Reply With Quote
The Long long long trip Foiled Again Full-Timing, Winter Living & Workamping 39 03-24-2016 10:27 AM
Our long, long trailer (AKA 19' CCD) crazylev 1997 - 2004 Bambi 60 05-11-2006 12:53 AM
There's a long, long trailer in front of my house - 2004 Classic Porky Pig 2001 - 2005 Classic 35 01-28-2004 05:28 PM
Movie: The Long, Long Trailer fritzs Our Community 5 12-29-2003 03:46 PM
