Old 11-01-2005, 08:28 AM   #1
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
honda generator replacement in 345
I know I saw pictures somewhere in here on replacing the kohler generator with a Honda EV6010 but can't find it. Last sunday we hosted a "boondock" party in our MoHo and the generator ran for about 3 hours. It started out fine and would run the microwave but you could hear the load hit it. We then were just running the overhead lights and the generator would run at a steady rpm for a while, then idle down and sound like it would die (but did not), lights would dim and then about 15 min later go back to stock idle and the lights would brighten. A one point it the rpm went way up and the lights dimmed again. We made it thru then night with it running. Our mechanic had looked at it a while back when the problem was it "disieling" after it ran for a while and we shut it down--at that point he said it was on its last legs. Any idea on the rpm situation and help with the link for the honda replacement? thanks
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 11-01-2005, 09:17 AM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
It sounds like you have either a field winding, or a brush in the generator itself that has one foot in the grave. Rebuilding it would probably cost more than it is worth, but I would get a second opinion from another mechanic before going out and buying another unit. They are expensive, andit would be bad to find out it was a loose connection somewhere.
Old 11-03-2005, 09:40 AM   #3
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
I have an EV6010 in my 84 310. I could post a picture if you would like. I've never seen the generator compartment in a 345 so I don't know if they are the same size.
Here's a post in an old thread which mentions a good source for the EV6010.
http://www.airforums.com/forum...honda#post6054
guy99 is offline   Reply With Quote
Old 11-03-2005, 10:23 AM   #4
str8strm's Avatar
unit size
they are smaller then the Kohler we have I thought I saw a post a while ago that showed someone moving it in with a forklift but have not been able to find it interestingly enough when I spoke with our RV mechanics about it they were more inclined to go with Onan?! The Hondas price out at about 3400. with mufflers etc right now thanks for the link
AIR 7992
Old 11-03-2005, 12:01 PM   #5
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
There is some information about this subject (along with Honda generator and generator compartment dimensions for a 345) on this thread:
http://www.airforums.com/forum...or+compartment
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 11-03-2005, 12:57 PM   #6
str8strm's Avatar
thanks
that was the link I was looking for thanks Did you make your trip to Vegas yet? We had our "Thing" up at Pismo as our tow vehicle and it was a toss up as to whether the MoHo or VW got the most looks Debbie
AIR 7992
Old 11-03-2005, 01:27 PM   #7
RivetAddict
swebster's Avatar
Ha! Yes, to Vegas and back with only one minor mechanical (cracked header collector transition within 5 miles of home). I know what you mean about the looks. The classic AS/VW combination certainly garners a lot of attention.
Steven Webster
AIR 1760
Winterizing a 345 Motor Home winner Airstream Motorhome Forums 11 09-29-2007 12:56 AM
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
Door-Step Cycle -345 winner General Motorhome Topics 8 10-04-2002 02:19 PM
Classic 345 davidz71 Our Community 1 07-26-2002 08:54 PM
345 Hill Climbing ViewRVs Mechanics Corner - Engines, Transmission & More... 12 04-18-2002 11:52 AM
