Old 05-15-2009, 08:23 AM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Help with Heat/Defrost/AC Rotary Switch
I have a 2002 chassis Land Yacht (Gas) 30' . The Climate Control has a hissing noise. I unscrewed the panel and quickly noted silicone all over the back of the unit. It was very difficult removing the silicone but it did reveal the cause of the hissing noise and the reason for the silicone. The white lead-in wire was being held in the port with the silicone but it broke loose over time. I temorarily forced a piece of tapered plastic in the port to stop the hissing (I suppose it is vacuum). Can anyone tell me if the white wire has important significance, or can I leave it unplugged with the stopper in the port just to stop the hissing.
Can someone explain the principle of how the heater/air/defroster rotary switch works.
Buying a used MH is a challenge.
Thank you.
Steve
spat61 is offline   Reply With Quote
Old 05-15-2009, 08:30 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Vacuum 101
The selector uses vacuum to operate blend doors and control valves by taking regulated manifold vacuum from the engine and sending it to a combination determined by the position of the selector lever.
If the white vacuum hose has vacuum all the time the engine is running, it is the main feed for the selector, and it must be plugged in so the various doors and valve will operate. If it has no vacuum unless the selector is in a specific position, it can be blocked off, and everything but that one item will work, up to a point. Bear in mind some settings of the selector require use of more than one door, and leaving one out of the system will hinder the effectiveness of the system.
When should I defrost? AIR-Quarius Refrigerators 12 03-22-2009 08:38 AM
Replacement for Leviton rotary light switch mharrison@ie Lights - Interior & Exterior 6 01-25-2009 01:44 PM
fridge not coming back on after defrost! jeff&jess Refrigerators 3 09-30-2006 08:37 AM
Rotary 12V Bath Vent Switch Condoluminum Electrical - Systems, Generators, Batteries & Solar 4 05-04-2004 08:02 AM
Rotary Light Switch 74SovereignInt. Electrical - Systems, Generators, Batteries & Solar 20 10-15-2002 06:31 PM
