Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 10-18-2006, 08:29 PM   #1
scottf3334
Profile:  Davenport , Florida
Help shifting gears
After looking for a few months, I finally got my 74 Argosy motorhome. Drove it from NJ to FL. Now for the fun part. I've already gotten rid of the plastic toilet and put in a Sealand Traveler Lite. Replaced most of the weather stripping around the door and windows. Got new 3 way switches for the lights that would pop on when we hit a bump, replaced the dash indicator bulbs, so I would know when the turn signal or bright lights were on.
Replaced the Univolt with an Intelipower. BTW the Univolt almost melted an extension cord, it was drawing way too much current and not charging the batterys.
Repiped the water system with PEX, the seller we bought it from said it was winterized and he didn't want to dewinterize it because winter is comming, turns out it was like a sprinkler system, way too many splits to save.
There are many more things to do and I know the forum will be my most valuable resource, as it already has been. Thank you to all of the people who give their knowledge when someone needs a little help.
Does anyone know where to get a shift indicator wire, rod or whatever it is , so I can tell which gear I am in? I'm pretty sure it is standard Chevy stuff, but after scouring the internet I just can't seem to find what I need
scottf3334 is offline   Reply With Quote
Old 10-18-2006, 08:43 PM   #2
scottf3334
pictures
Here is a fuzzy picture of what I'm talking about. The motorhome is a 74, but I'm pretty sure the chasis is earlier. Thanks
Name:	000_0092 (Small).jpg
ID:	27154   Click image for larger version
Name:	100_0335 croped (Small).jpg
Old 10-18-2006, 09:19 PM   #3
overlander63
overlander63's Avatar
Profile:  .... , California
That piece is cast on the shift collar. If the scutcheon that reads "PRND21" is still there, you can try using red fingernail polish to paint the piece that sticks up to be visible behind it.
(that guy from Inland RV)
Old 10-18-2006, 09:32 PM   #4
ralley
Profile:  Prince Frederick , Maryland
Scott: I think your best bet is a junkyard for these parts. Call around, take a tool box. Make a list of what you need and be prepared to negotiate!! Folks on the forum may, if they have a junkyard nearby, be able to procure parts for you. Good Luck!
ralley is offline   Reply With Quote
Old 10-18-2006, 09:54 PM   #5
scottf3334
Thanks for all quick replies.
Just to clarify a little (the picture is awful), I have the "Park R N D D1 D2" piece, just not the part that starts where the column has a slot and extends to the back of the "Park R N D D1 D2" piece.
I was thinking about it being a cast piece, but then how would it move with the tilt steering wheel?
Maybe someone with an older Argosy can run out and take a look at your steering column to give me an idea. Thanks again
Old 10-18-2006, 10:29 PM   #6
85/345
Profile:  Marietta , Georgia
I have a 78 Argosy that I use for parts and I may have what you need. The Argosy is stored about an hour from where I live and I won't be able to find out for sure until next week. As soon as I find out I'll let you know.
85/345 is offline   Reply With Quote
Old 10-19-2006, 06:05 AM   #7
overlander63
It doesn't. That's why it's so far away from the window with the letters, so it doesn't interfere with the window. I have an older GM vehicle in my shop, with tilt wheel, I will try to take a photo of it, so we can compare them.
Old 10-19-2006, 09:56 PM   #8
scottf3334
Thanks for all the great info. Pictures would really help out, I just cant seem to visualize how it should be.
85/345, you have an Argosy you use for parts, actually there is a few other things I could use as well, if you are just parting it out. Please let me know, and thanks.
Old 10-19-2006, 10:59 PM   #9
85/345
As long as I don't need them I'm sure we can work something out. Just let me know what you need and when I go to look at the shifter thingamajig I'll look at the other stuff too.
Old 10-20-2006, 05:07 AM   #10
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
The indicator was broken off on Chummy when we bought it. Each time I would start off I put the selector all the way to the right and then counted up, 1 gear 2 gear, drive. When I redid the dash I tried to find the part to fix this with and was unable to locate anything even close. I ended up taking a brass 3" screw and driving it into the housing. Looks kind of screwy but it works.
Chaplain Kent
1982 280 Turbo Diesel Motor Home (Chummy)
http://travelswithchummy.blogspot.com/
Chaplain Kent is offline   Reply With Quote
Old 10-20-2006, 07:17 PM   #11
noiva
noiva's Avatar
Profile:  Chesapeake , Virginia
Images: 46
Now that's what I call "Yankee ingenuity". We southerners would take a hammer and probably crack the whole steering column.
Tim
No More MoHo
1989 34X
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Old 10-24-2006, 09:29 PM   #12
scottf3334
Smile
Who hoo I found it. For all of you out there with various things sticking out of your steering column, this is what you need and only $14.00. Thanks to everyone for all of the great info and ideas.
here is wher I found it. http://www.classicperform.com/Store/.../7172OSCIC.htm
Name:	Shift indicator thingy.jpg
Old 10-24-2006, 09:32 PM   #13
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Scott...nice find. Where can someone purchase this ?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 10-24-2006, 10:02 PM   #14
scottf3334
It is kind of hard to find. goto
http://www.classicperform.com/6092chevtrk.htm
then scroll down to Steering Columns & Components ,,
then scroll slowly down a little more to Shift Indicators
you'll see it, click on the photos to make sure you got the right one
They are the only place I could on the net
What's your tow vehicle's rating? John Community Polls 109 08-21-2008 08:14 AM
Newbie Tow Advice Needed Mr. Bliss 1999 Safari 16 02-25-2003 11:01 AM
tow vehicles paul k Tow Vehicles 96 01-19-2003 10:59 PM
Which tow vehicle for a 19' Bambi? Jay_Iski Tow Vehicles 48 07-15-2002 02:43 PM
