Old 11-17-2008, 08:18 AM   #1
heater/propane gauge
I have a 85 345 and need to replace the front duo therm heater-what has anyone used to replace this unit, also has anyone tracked down problems with propane tank guage on control panel(mine always reads full). thank you
mlmarch is offline   Reply With Quote
Old 11-17-2008, 08:26 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
As far as the propane guage, it might be the plastic guage sending unit. Take it off the tank and go see your local propane distributor. (It should be a magnetic, so it does not penetrate the tank, attached with 2 little self tapping screws to the main sending unit which does penetrate the tank) They should have them in stock. I know Heritage Propane has them, if they are in your area.
If you are not sure about this, take the whole motorhome to them and let them take the sending unit off.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 11-17-2008, 10:52 AM   #3
345 duo therm heater
I have been told that the NT20S Surburban heater is the replacement-however they stated that the exhaust ports on the outside are not in the same place. The skin would have to be patched and new holes cut it.
Can anybody verify this?
Old 11-18-2008, 11:46 AM   #4
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Check my post on the replacement of my rear furnace. The front is similar with the only exception of having to mod the front cover of the new unit to blow heat out under the sink cabinet. The exterior mod is simple. Just get a piece of stainless steel to cover the old holes. If needed I can get some pictures of my front installation.
Rob
http://www.airforums.com/forums/f311...ace-35418.html
Robfike is offline   Reply With Quote
Old 11-18-2008, 06:09 PM   #5
Robfike's Avatar
Speedway , Indiana
Michael,
Here are some shots of our front suburban furnace install. The furnace feeds the round outlet on the front side of the under sink cabinet, as well as the rectangular outlet in the hall side of the cabinet. I think the original furnace must have been shorter in depth as the front cover has been modified to feed the rectangular vent.
Hope this helps, Rob
Name:	front furnace 001.jpg
ID:	71539   Click image for larger version
Name:	front furnace 002.jpg
Name:	front furnace 005.jpg
OPD valves with wire to propane gauge eubank LP Gas, Piping, Tanks & Regulators 2 09-29-2008 02:59 PM
Propane gauge nazz300 LP Gas, Piping, Tanks & Regulators 36 05-03-2007 08:13 AM
Thermx propane heater jujubee_1 Member Introductions 1 03-20-2006 04:17 PM
Propane tank gauge Jim Miller LP Gas, Piping, Tanks & Regulators 6 04-09-2003 04:25 PM
Propane Heater Krazykraut General Motorhome Topics 3 12-29-2002 01:29 PM
