Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 07-22-2008, 06:44 PM   #1
educator
educator's Avatar
Profile:
Heater – A/C control
Heater – A/C control unit has gone bad on my 345. I am unable to control the heater or air-conditioning vacuum dampers. Has anyone replaced this control? It is not a Chevy or GM part. We guess it may be a Chrysler part, but have no idea as to the part number may be.
Last edited by azflycaster; 07-23-2008 at 03:05 AM. Reason: standard font and size applied
educator is offline   Reply With Quote
Old 07-22-2008, 10:08 PM   #2
bkahler
Profile:  Jefferson , Arkansas
You are correct it most likely is a Chrysler unit, at least the one in our 1984 310 was. I believe if you look for a early to mid 80s unit you'll find what you need. I got ours off of eBay for about $25. You can also just take the control unit to a Chrysler dealer and they might be able to get one for you. I believe there is a part number on the unit itself somewhere.
This post http://www.airforums.com/forums/f159...ses-33272.html has a copy of the vacuum diagram. It mostly matched mine with only minor differences. I spent several hours playing with the various vacuum lines making sure everything was working correctly.
The other thing to watch out for is vacuum leaks. Another reason our control didn't work was because someone plugged the vacuum line going up to the dash because of a cracked hose. That kept the vacuum gauge and the a/c controls from working. Took me a while to figure that one out!
Hope this helps.
"Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
Heater Control Problem Northern Pik Member Introductions 0 05-28-2008 05:38 AM
Hot water heater - can't find temp control dano Water Heaters, Filters & Pumps 5 04-06-2008 02:37 PM
Auxiliary Heater water control valve noiva Mechanics Corner - Engines, Transmission & More... 4 12-16-2005 03:50 PM
Heater Control- Warm Cool selector RonJudi General Motorhome Topics 5 01-31-2004 07:59 PM
Heater, Airconditionor Dash Control cooperhawk Airstream Motorhome Forums 4 11-11-2003 08:38 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
