Old 07-10-2009, 07:28 AM   #1
Smile GFCI in Campgrounds Always Trip
My Coach will trip the GFCI outlet in every campground when I am hooking up to 20 amps or less. This is also true when a portable power generator is provided which has GFCI outputs. If you take an ohmeter and check the neutral to ground pins on your power plug you will measure a direct short.
This is not neccessarily a Coach defect or miswired circuit. After some investigation I found that it is the Inverter/Converter which is causing the GFCI to trip. It seems that most of them have a relay circuit which directly hooks the Coach ground with the neutral wire. The relay will operate when AC shore power is applied to the Inverter and remove the connection. However, this is a timing problem. If the GFCI trips quickly then the relay will never see shore power.
The reason for the relay circuit is that the source of power for the Coach must have the neutral connected to the ground in one spot. If the Inverter is the source of power than this connection must be made in the Inverter.
By the way GFCI circuits do not require a ground connection. Older houses without ground circuits can still be fully protected with GFCI outlets. The GFCI monitors the current in both the neutral and hot leads and compares them to make sure they are essentally equal.
I am investigating ways of getting around this problem. There is usually no problem with 30 or 50 amp circuits since they do not use GFCI outlets.
Howard Lefkowitz is offline   Reply With Quote
Old 07-10-2009, 02:23 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
This would be the reason the circuits in your coach indicate an open ground when using the Honda 2000?
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 07-11-2009, 07:56 PM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Howard, I had hoped to see you in Madison but was told you were down with pneumonia. I trust you're OK now.
Howard WBCCI 5957
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 07-12-2009, 07:10 AM   #4
Talking
Howard WBCCI 5957
Yes I am just about recovered. I spent three days in the Hospital. Nasty stuff. Final check-up in two weeks. See you soon.
Howard
My Trailer Trips the GFCI Circuit - Help? weiss1957 Electrical - Systems, Generators, Batteries & Solar 29 12-30-2008 08:46 PM
Gen. GFCI tripping Cochese Generators & Solar Power 1 08-13-2008 05:54 PM
gfci help oakie Lights - Interior & Exterior 2 06-07-2007 08:50 PM
Gfci achip Electrical - Systems, Generators, Batteries & Solar 4 07-22-2006 11:52 AM
Gfci jcf48 Electrical - Systems, Generators, Batteries & Solar 0 07-21-2006 11:00 AM
