Old 12-04-2005, 01:27 PM   #1
Red face Genset exhaust routing ?
I took the frig outta my 1977 Airstream Argosy 20', since it crapped out on me. In doing so I made note of how the plastic "vent" went up the side of the body and out through the top. It occurred to me that an "interesting" possibility might be to run the (wrapped) genset exhaust up through the floor and INSIDE of the refrigerator vent, up through the roof. I plan on replacing the plastic vent with an aluminum vent of my own fabrication; between that and the well-wrapped exhaust, can anyone tell me why this wouldn't be a good idea? It would likely be quieter and would definitely be MUCH less noxious than it's present "out the side" location; as many of you know, there's a kit to run you genset exhaust up along the side of one's coach. So which half of an idiot-savant am I being with this idea?
TheGanzman is offline   Reply With Quote
Old 12-04-2005, 02:01 PM   #2
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Might not be a good idea to run any exhaust up through the interior compartment of the coach, even if it's behind the fridge and in a double walled flu. Too many opportunities for exhaust to get into the living area.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 12-04-2005, 03:18 PM   #3
I'd figure on running a "no connections" run through the actual coach itself, with good exhaust/body sealing at the floor and ceiling areas. . .
Old 12-04-2005, 06:34 PM   #4
RivetAddict
swebster's Avatar
I recently had a misfiring genset issue and the force of the backfires and flames coming from the exhaust were enough to remind me how much force the exhaust has to take. While I like your concept, IMHO - keep it outside.
Steven Webster
AIR 1760
Old 12-05-2005, 07:08 PM   #5
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
My thought would be how it might affect the working of your refrigerator. The vent is an important part of the mechanism in a Dometic propane unit. The temperature of the exhaust can determine how well or badly your unit will cool.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 12-05-2005, 10:55 PM   #6
Yeah, bad idea. . .Seemed like a good idea right up to when it didn't!
Old 12-06-2005, 08:00 AM   #7
1994 30' Excella
I have a whole section of my garage devoted to my bad ideas. There are beautifully crafted boxes which will never see the workings intended for them; pipe purchased that will go no where; switches that won't switch; and those thingies I just had to have at the time because they were going to be perfect. Who knows maybe someday there will be a use and then I will be able to write the perfect thread in this forum.
Chaplain Kent
Old 12-06-2005, 08:05 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
ChaplainKent,
Never fear the future use of all those lovely items has been established!...One day in the distant future there will be an Estate Sale and some one else will become the proud owner of your projects to be.... I know I have purchased my fair share, and look on the bright side...you are supporting the local economy with your purchases
Aaron
WBCCI #XXXX AIR #2495
2008 Interstate 3500 Generator Exhaust Routing Question solar-guy Sprinter and B-van Forum 3 03-06-2012 06:19 AM
1967 Gray water Routing amoretti Waste Systems, Tanks & Totes 5 05-02-2010 09:22 PM
Breakaway cable routing. ROBERTSUNRUS Brakes & Brake Controllers 16 12-27-2008 12:33 AM
Pipe Routing trevel Fresh Water Systems 4 12-15-2006 09:17 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
