Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 04-30-2003, 08:05 PM   #1
jim8860
jim8860's Avatar
Profile:
Generator No Start
I just came back form my trip and here is my proplem. Before I left the generator work perfect. Drove 600 miles and parked in the finest hotel that I can find parking lot and fired up the old generator for about 3 hrs. All was well. Drove 250 more and park at the camp site. We lost the power at the site that night so I when to start the generator and no luck no start. So the next day I check every thing out an this is what I found. When I hit the "start" button I think from what I can tell there is a fuel pump that runs while I hold the start button on. Then I took a test light to the stud on the starter and ther was no power there. I check 2 fuses and the look good. Any ideas???
PS I have a 7.0 Onan generator in a 95 MH LY
jim8860 is offline   Reply With Quote
Old 04-30-2003, 09:21 PM   #2
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
Low on fuel? Most generators will run out of gas at 1/4 Tank level.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 04-30-2003, 10:53 PM   #3
FrankR
Profile:
Gen NO GO
I have never known a owens gen set but, there is a very famous gen co named Onan. The usual not run senario is low oil. There is a sensor in the oil pan that controls power to the fuel pump. Spin the starter and spray just a few whiffs of starting fluid at aircleaner.
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 05-01-2003, 02:20 AM   #4
jim8860
jim8860's Avatar
Profile:
Typo on they name I had no idea how I typed that name. As for no start it do not even crank over . Oil is fine and gas is full . The starter motor does not even get 12 volts. If the motor did get 12 volts then the starter motor is bad. From what I have read it point to the fuses . I only found 2 and they are good. Is there any more may be off the generator but in the MH?
Old 05-01-2003, 08:09 AM   #5
74Argosy24MH
Profile:  LOST , Hawaii
My Onan grounds to start/stop so if your fuel pump is running you have power and that part of the starting circuit should be ok. If there is no power at the starter with the start switch closed I would check the solenoid and board.
John
74Argosy24MH is offline   Reply With Quote
Old 05-02-2003, 03:05 PM   #6
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 143
Possible Stuck Switch
If you do identify the problem to be in the remote switches, check ALL of the remotes for proper operation. Just one of the remote switches stuck in the "Kill" position (or internally shorted) would pre-empt proper operation of the remainder of the switches.
Dennis
WBCCI # 1113
AirForums #1737
Old 05-03-2003, 04:43 PM   #7
jim8860
jim8860's Avatar
Profile:
Well I check out the old generator and what I found is the circuit bord was bad.The cost of the bord was $172.00.Thanks John (74Argosy24MH) you were right!. All seems good now. Untill next trip. Jim
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
Let's start with the Fridge.... GT1963 Refrigerators 6 03-03-2004 09:01 PM
Where to start? stellablu General Repair Forum 0 08-08-2003 01:02 PM
where do you start?? skip General Repair Forum 6 07-20-2003 06:27 PM
Aaaargh!!! Motorhome won't start!!!! AGAIN!!! eraffety General Motorhome Topics 14 01-19-2003 06:40 PM
