Old 10-18-2004, 12:12 AM   #1
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
gasoline smell after fill-up
I only notice this after I'ved filled up, then after burning off fuel it goes away. This time I filled up so that there would be minor condensation due to weather, and since I haven't burned it yet, it reeks like petrol in the rear of the MH.
I read a post by Peter that his did the same and it was a missing nut on top of the tank. How tough is it to reach? I think this may be a mechanic's job, or i should try not filling to max next time.
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 10-18-2004, 05:13 AM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Exclamation
Originally Posted by Astrodokk
.............I read a post by Peter that his did the same and it was a missing nut on top of the tank. How tough is it to reach? I think this may be a mechanic's job, or i should try not filling to max next time.
You have to drop the tank. Get it taken care of yesterday.
It could just be the return line at the filler spout. Since that hose is hard to find, its often replaced with a non gasoline resistant hose, which only lasts a few years.
Don't wait, this is a very dangerous situation!!
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 10-19-2004, 05:54 PM   #3
Fuel smell
Hi,
I had the same problem after filling up.
After much searching ,it turned out to be the filler neck vent tube.
The vent tube is sweat soldered in side of the neck a couple of inches down from the cap.
It had cracked where it was soldered to the larger filler tube.
It looked like someone in the past had damaged it when installing possible a replacement hose?
I removed the complete upper assembly from the hoses and re soldered it.
Problem solved
Hope yours is that easy
It's hard to believe such a small crack can cause such a BIG odor
ol'George
George is offline   Reply With Quote
West Gasoline IS STILL CHEAP for Rockdocking Ray Eklund Boondocking 22 06-23-2008 08:38 AM
$4 per gallon gasoline JimGolden Off Topic Forum 94 05-03-2007 10:49 AM
Gasoline tank replacement? Astrodokk Classic Motorhomes 10 03-18-2007 07:40 PM
Gasoline Can For Generator Fuel PARKS1963 Generators & Solar Power 9 08-12-2006 09:14 PM
Gasoline prices myoung Dollars & Cents 5 02-09-2006 08:47 AM
