Old 10-06-2004, 01:34 AM   #1
Mr.Motorhome's Avatar
Question Gas tank sending unit questions
My gas gauge is not working on my 76 argosey 28.0 MH
I was wondering if any of you all have had the joy of dropping the gas tank and putting in a new sending unit? Is the sending unit just your standard chevy p-30 gas tank unit or a unit just made for motor homes only?
Also any tips on dropping the tank would be great too!
Thansk,Alex
Mr.Motorhome is offline   Reply With Quote
Old 10-06-2004, 06:14 AM   #2
LOST , Hawaii
Are you sure it is the sender? Power flow is from the gauge to the sender, check for voltage at the sender. The senders are standard 0-90 ohm but do have a shorter separate pickup for the generator.
John
74Argosy24MH is offline   Reply With Quote
Old 10-06-2004, 08:17 AM   #3
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
drain the tank, and be careful with the rubber hose you will go into shock if you have to replace. if it is the sendor in the tank you will have to repair. it is a resistor .
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 10-06-2004, 10:11 AM   #4
I grounded the sending wire from the gauge and the gas gauge starts going up.
So your saying the restistor just needs to be replaced? Is a replacement sender not available anymore?
Thanks,Alex
Old 10-06-2004, 10:57 AM   #5
LOST , Hawaii
The resistor is not a separate part, you will need the whole sender. RV junkyards, GM, maybe but they are dropping the P3x parts, Workhorse. Just make sure it has the pickup for the generator.
John
Gas Plumbing Questions aztlanco Plumbing - Systems & Fixtures 15 09-20-2004 12:42 PM
27' B tank layout and weight reduction questions pneum0 2002 Safari 12 09-13-2004 12:33 PM
Fresh Water Tank Questions srgntpepper Fresh Water Systems 6 10-19-2003 11:03 AM
gas tank sensor wb13798 Mechanics Corner - Engines, Transmission & More... 21 08-21-2003 06:04 PM
gas tank wb13798 Mechanics Corner - Engines, Transmission & More... 6 08-17-2003 12:49 PM
