Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 04-17-2008, 05:23 PM   #1
geodrake
geodrake's Avatar
Profile:  olathe , Kansas
Gas Tank Filler & Vent Hose
On our way to RGV in Dec. I noticed that i had a gasoline leak during fueling. A quick crawl under the MH while fueling indicated that there was some sort of leak in the filler hose. I stopped at an RV dealer and paid them $149 to fix it. 300 miles later i stopped for fule and sure enough it was still leaking.
Now I'm home and have time (and inclination) to repair it myself. I checked with Airstream and was told that it is a chassis problem and I would need to go to Chevy (It's a 1993 Airstream Legacy setting on a P-30 chassis). GMC dealer learned that the part is MFG discontinued but found the filler hose under Workhorse. Ordered, but no part no for the vent hose.
Has anyone else had this leak?
How difficult is it to replace.
Any idea where the vent hose can be obtained?
geodrake is offline   Reply With Quote
Old 09-25-2008, 06:44 AM   #2
FrenchBern
Profile:
I am having the same trouble on 94 legacy I just bought. Gas filler hose is more of a sieve than a leakproof tube. I managed to disconnect one end off yesterday and it took over an hour and that was the easier end. I sure am open on any suggestions on how to remove the other end.
I read that many GM P30's motorhome owners have the same problem. Anyone knows where I can find a replacement hose 30" long which will not dissolve from gas fumes?
Live and LET live
FrenchBern is offline   Reply With Quote
Old 09-25-2008, 07:45 AM   #3
overlander63
overlander63's Avatar
Profile:  .... , California
Bernie, it is standard (for North America) fuel fill hose. When you get it removed (since it is leaking, cut a slice in the hose where it connects to the metal joint, and slide it off), measure length and diameter. I can get replacement hose from almost any NAPA or hydraulic repair business.
Here is a link to example:
Fuel Filler Hose - Universal at PartsAmerica.com
(that guy from Inland RV)
Old 10-12-2008, 07:53 PM   #4
choctawmel
Profile:  choctaw , Oklahoma
I did that. It don't just "Slide off" there is a wire reinforcement and the hose is concreted/bonded on both ends. I had to cut hose down to the wire and rip it off by bruit force in little bitty pieces.
Now I don't make a puddle of gas on the ground when I fill.
mel
choctawmel is offline   Reply With Quote
Fuel leak in the gas filler hose mrgump Airstream Motorhome Forums 5 04-04-2007 03:51 PM
Fresh Water Tank Filler Dano57 Fresh Water Systems 23 12-17-2006 07:55 AM
Twin water tank filler necks? FreshAir Fresh Water Systems 0 07-11-2006 11:41 PM
Filling H20 Tank via Hooked-up Hose Mike76251 Fresh Water Systems 9 03-20-2004 08:39 PM
My EU2000i & gas can & boondocking Raptorrider2001 Generators & Solar Power 5 04-03-2003 10:12 AM
