Old 09-20-2009, 02:37 PM   #1
2010 16' Sport
1982 28' Airstream 280
Denver , Colorado
Gas pedal and cruise control question
82 280 motorhome. Require a lot of foot pressure.
I have an aftermaket- new- cruise. Anyone ever installed one?
Questin is- will these aftermarket systems overcome 5-10 lbs of pedal pressure?
Anyone ever installed a different gas pedal?
Jim in Denver
willerjim is offline   Reply With Quote
Old 09-20-2009, 03:02 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would try and figure out what is the cause of the heavy foot pressure before you attempt to install the control. Most controls pull directly on the throttle arm at the carb or fuel injection body and may have trouble. Is the problem in the peddle hinging or is the cable just rusted up?
Try disconnecting the peddle and see if the problem is in it as apposed to the cable.
2004 Excursion 4x4
Cruise control jgwild Argosy Motorhomes 1 07-31-2009 11:27 AM
cruise control choctawmel Mechanics Corner - Engines, Transmission & More... 13 12-27-2008 06:14 PM
towing with cruise control brunoffrance Towing, Tow Vehicles & Hitches 7 06-14-2006 05:28 PM
Cruise Control Chaplain Kent Mechanics Corner - Engines, Transmission & More... 4 10-14-2004 08:56 PM
No cruise control on '92 30' fangthorpe Mechanics Corner - Engines, Transmission & More... 3 05-09-2003 10:46 PM
