Old 08-06-2017, 01:53 PM   #1
1988 34.5' Airstream 345
Lafayette , Louisiana
Gas Gauge
I recently put in a new gas take in my 1988 345 airstream but the gas gauge they installed moves about 1/2 tank when driving. Does anyone have any recomendations to get a stable gas tank level indicator installed?
Jim Keaty is offline   Reply With Quote
Old 08-06-2017, 03:41 PM   #2
Jim, I know of several people that have used this 90 ohm sending unit as a replacement for their original one. I have it in my tank but the tank is not yet in service so I can't say for a fact that it works.
You'll need to drop your tank and most likely rework the opening for the sending unit.
Old 04-18-2018, 06:55 AM   #3
gas gage
Hey Bob,
Is your gas tank sending unit working well? My gas gage still jumps all over the place but I don't know what gas gage sending unit they have installed.
Old 04-22-2018, 10:03 AM   #4
Brad that last message was for you. I wanted to know if that sending unit is working on yours
Old 04-22-2018, 10:44 AM   #5
Jim,
My Argosy isn't driveable yet and probably won't be until this summer so I won't know until then if the gauge works or not. I'm pretty sure there is someone else on the forum who used the same gauge.
The gauges in your coach were made by Teleflex and from everything I've been able to find out is Airstream set the system up to use the same 0-90 ohm signal that was standard for GM at the time.
Does your sending unit work at all? If so take a resistance reading with the arm in one position and then at the other position. If one end is around 0 and the other is around 90 then it should work.
Old 04-22-2018, 10:54 AM   #6
It works but it jumps almost a 1/2 tank with the gas in the tank moving around
Old 04-23-2018, 01:43 PM   #7
It sounds like the gas tank doesn't have any baffles in it. If that's the case a longer sending you will probably help but it's hard to say how much until you try it.
Old 04-23-2018, 02:44 PM   #8
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
The older 'quadrant' style gauges came with a resistor that sits across the terminals to slow down the response to changes in signal from the sender....maybe your new gauge is meant to have something similar?
martin300662 is online now   Reply With Quote
Old 04-23-2018, 03:25 PM   #9
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Wow that is a awesome price, the OEM units, if you can find them, are a fortune.
One note on that unit, it does not have the fuel supply & return line in the flange, I bet they could be added.
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
Old 04-23-2018, 04:32 PM   #10
Martin, the original Teleflex fuel gauge I pulled from the 345 had a similar resistor in place. If you look at the first photo you can see it in the 2nd gauge from the right on the bottom row.
ID:	309403Click image for larger version
Here's a close up of a Teleflex 0-90 ohm propane gauge I bought that also has the resistor in place.
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1999 Safari 1 08-18-2014 08:25 PM
Gas Gage Big Denny General Repair Forum 3 08-13-2012 04:20 PM
Gas Gage problem two2go Land Yacht/Legacy Motorhomes 5 08-05-2012 10:59 PM
Locking Gas Cap for 2003 AS Gas Motorhome spat61 Land Yacht/Legacy Motorhomes 11 10-27-2008 11:37 AM
Gas Gage deano Airstream Motorhome Forums 13 08-21-2003 07:33 PM
