Old 06-15-2005, 12:58 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Frozen set screw
My driver side rear view mirror can not be locked down because the set screw is frozen. I assume that it is frozen because the set screw is steel and the mirror fixture is aluminum.
Penetrating oil hasn't helped so far.
Any more ideas?
guy99 is offline   Reply With Quote
Old 06-15-2005, 05:36 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Heat
Any more ideas?
Apply some heat to the area. The aluminum will expand and contract at a different speed fromt the steel, and after heating it up, try loosening it before it cools off again. Just be careful, as aluminum melts at a much lower temp than steel.
Old 06-15-2005, 08:28 PM   #3
Tinsel Loaf's Avatar
Yes, apply heat. You can use a large sodering iron on the set screw which should toast some of the crud alowing it to break free.
Tinsel Loaf is offline   Reply With Quote
