Originally Posted by swebster@myrvadvanta
I've been chasing an intermittant issue with my fridge for almost a year. It seemed to turn off on it's own from time to time. It always seemed to be something with the 12V system and since the PO had wired an inline fuse into the 12V dist panel I thought maybe it's just shakes loose from time to time. Well today I got a little further. I noticed that the on/off switch would come back on if I pushed it. So a little di-electric cleaner and the switch is fine now..
I, also, had an identical problem with the switch as you have described.
Also had a problem with the main board - sent them both to:
http://www.dinosaurelectronics.com/S...0Bulletin2.htm
Rebuilt both boards for less than 200 bucks. Good people to do business with.
If I remember correctly, the source for the 12 volt heating element power is directly from the alternator, not the batteries. It is installed this way to prevent the heating element from draining either house or coach battery. The main fridge board is not supposed to switch to 12 volt power until it senses a voltage in excess of (I think) 13.4 volts. Again, a safety circuit to prevent the 12 volt heating element from draining the battery(ies).
BUT...there's more...
Now it seems to work in all modes until I turn the key to ignition start. It's fine coming on or off shore power and blows the fuse as soon as I start the engine..
Remember that once the main board senses a lack of 13+ volt power (and turns to 12 volt heating element "Off"), there is a delay of about 20 minutes before the gas burner will ignite - I think this is a safety feature such that if you pull into a gasoline station and turn off the ignition switch, the gas flame will not attempt to ignite while you are pulled up next to the pump.
I have yet to chase wires, but since chasing wire is my least favroite thing in the workd to do...does anyone have thoughts on where to look...bad ground....ideas?.
Since it seems that there were no "standards" in place at the factory when they were building these beasts, and, for sure, most wiring is unique and without documentation on each unit, once you trace a line out, permanently mark it or make a diagram to insert in your manual. Like you said, tracing wires is a PITA (especially if you are working alone), but if you document it, it might save you from having to do it again in a couple of years.
Luck
